03-15-2019, 07:21 PM | #1876 | |||
A guy with a truck
Re: How to: Ruin a perfectly good C10
Look for ENDURATEX Madrid 2309 CLASSIC Metallic Medium Blue Vinyl
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-15-2019, 07:48 PM | #1877 |
Have you found a rattle can dye that matches the vinyl?
03-15-2019, 10:26 PM | #1878 |
That upholstery is pretty sweet and really goes the extra mile to make the truck unique!!!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
03-16-2019, 01:09 PM | #1879 |
A guy with a truck
The last can I used was ordered from a Corvette restoration shop, as those cars used the same blue metallic vinyl. I don’t know how close this vinyl I’ve ordered will match the stock stuff, though, which is why I had them go ahead and re-cover the visors and dash pad, too. I can do a comparison against my armrests, which were painted with the rattle can, once the new pieces arrive.
Thanks for the kudos. Going for stock-ish, but not quite. Most non-C-10 folks probably won’t even look twice
03-16-2019, 02:17 PM | #1880 |
You can do it! It doesn't have to be "done." It doesn't even have to run, but it's a lot easier to get in and out if it does.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-16-2019, 03:57 PM | #1881 | |
03-16-2019, 08:12 PM | #1882 |
Did I miss it? How'd you get a MAF into the air cleaner?
03-16-2019, 10:00 PM | #1883 | |
A guy with a truck
No worries, should have everything in a few weeks MAF-less, speed-density via Fitech, but Holley’s new Terminator X is looking pretty good to me now. Check out dayj1’s “another way to skin the cat” thread for a good example of how to hide the MAF in a tall air cleaner. I’ve also seen guys use the cartridge type in the snorkel
03-16-2019, 10:12 PM | #1884 |
A guy with a truck
My new bellhousing arrived and I got right to bolting it on and stabbing the transmission. You can see just under the top-most bolt where the alloy unit has more clearance than the old Lakewood steel one. This is where the rear cover bolts needed some wiggle room. The new one is from Silver Sport, and is made specifically for LS to Muncie conversions. Should also work well with a TKO, if/when I decide to go that route and saves what feels like 60 lbs...
No pictures of the hydraulic throw out, but it set up beautifully with proper clearance. I couldn’t resist bolting up the Hurst shifter and pretending to row through the gears
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-17-2019 at 12:15 AM. |
03-16-2019, 10:20 PM | #1885 |
A guy with a truck
...and a few shots of the engine sitting in its rightful place. I particularly like the last one showing how nicely everything tucks up with the dropmember.
03-17-2019, 12:02 PM | #1886 |
You are making me want to do an LS swap....
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-17-2019, 12:12 PM | #1887 |
A guy with a truck
Jump on in, everybody’s doing it! Once this junk is “done”, I’ll be happy to come help
03-17-2019, 02:20 PM | #1888 |
Swap is looking on point!
03-17-2019, 03:41 PM | #1889 |
Everything looks great! What size is that booster/master set up? Is that a captain fab bracket hiding behind?
03-18-2019, 01:05 AM | #1890 |
A guy with a truck
Thanks Scoti!
Thanks, the booster is a 9” dual diaphragm from inline tube, wilwood master, and captainfab bracket with integrated clutch master
03-18-2019, 11:37 AM | #1891 |
I'm just glad to be here!
Looking good from here!
Nice job Chris.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-19-2019, 10:01 PM | #1892 |
Just spent the last week going through this build thread and found myself writing down ideas to follow up on and parts to look into for a few of my builds.
Excellent work on all fronts Chris - you are doing top notch stuff! What shifter boot are you considering for the Muncie? I replaced the one in the 70 GMC Jimmy with a new one (Amazon cheapie) and it ripped after using it for driving in/out of the garage... I should have known. |
03-19-2019, 10:06 PM | #1893 |
That engine is looking sick in the bay man. Top Notch.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
03-19-2019, 11:27 PM | #1894 | |
A guy with a truck
As for the shift boot, the plan is for a factory (or re-pop, most likely) oval-shaped 4wd boot and trim ring, just keeping with the stock-ish theme. Hurst makes this handy little piece to adapt the flat handle to a round-ish boot hole: https://www.hurstshiftersonline.com/...ommet-p590.htm
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-19-2019 at 11:36 PM. |
03-19-2019, 11:48 PM | #1895 |
A guy with a truck
Had some power steering hoses made-up at the local hydraulics shop yesterday. Quick turn, cheap, and fit nicely. The high-side snakes behind the tensioner bracket, while low side has a pretty much straight shot to the reservoir.
That allowed pressing-on of the pump pulley and then measuring for the serpentine belt. I’m happy to report that it only took two trips to the LAPS to get the right one Baby steps...
03-20-2019, 03:28 PM | #1896 |
A day late and $1 short...
You're killing it Chris, one step at a time. Your patience and eye for detail are paying off for sure!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
03-21-2019, 03:50 PM | #1897 |
Wow...the fit of the engine in that drop member is perfect....I dont know if you could even fab something remotely close to that at home!
03-21-2019, 04:47 PM | #1898 | |
A guy with a truck
Not with my skill set, I know my limitations Definitely a high quality product
04-05-2019, 11:06 AM | #1899 |
Great truck - great work!
...saw that you had some questions re. the clutch rod angle set up on another post and I'm working on the same subject so I thought I'd get you some photo's of an alternative set up - couldn't send photo's via PM so I'm using this post. Might help you and/or others: This is the NO LIMIT this set up for hydraulic clutch and looks much more straightforward - pulls the clutch master up higher, rod is straight, is on a flatter firewall area and uses the more popular mounting style master which allows for larger and/or remote reservoir. Plate is 3/16" |
04-05-2019, 02:53 PM | #1900 | |
A guy with a truck
