05-16-2010, 09:06 PM | #176 |
Registered Chevy Owner
Re: Yet Another s10 swap
Jeff, your filler looks great. I was going to do that, but I was scared to cut the bed side. Good job on it.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
08-06-2010, 09:52 PM | #177 |
Just so you guys didn't think I died, been working on making this pig go.
Getting ever so closer. Never liked being the rabit anyway. Last edited by jeffs51chevy; 08-06-2010 at 09:53 PM. |
08-06-2010, 10:25 PM | #178 |
Hey Jeff,
Glad to see that your back at it. I got mine fired up last week. What a beautiful sound!!!!!! Got my 4x4 rearend, with springs and a brand new blazer gas tank......all for $100.00. Im picking it up tomorrow. thanks again for the lead on CL. I spoke with guy today. He doesnt want to separate. Im still on the hunt. Thanks again brian
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan Last edited by rhodog77; 08-07-2010 at 08:05 PM. |
08-08-2010, 08:07 PM | #179 |
Jeff,
when you swaped to the 4x4 rearend, did you use the 4x4 leaf springs of just the axle. I got mine all broke down and ready to clean up. Didn't want to clean the new springs if the setup is wrong. thanks brian
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan |
08-08-2010, 09:27 PM | #180 | |
I found the Blazer springs to be sightly shorter than the pickup leafs, so I swaped them out. I'm currently trying to source s10 lightning or ZQ8 (I think) coded leafs. I haven't confrimed it personally, but they are supposed to be 1 1/2 inches lower than stock - goodbye lowering blocks. Hope that helped. Jeff |
08-08-2010, 10:13 PM | #181 |
"I'm currently trying to source s10 lightning or ZQ8 (I think) coded leafs. I haven't confrimed it personally, but they are supposed to be 1 1/2 inches lower than stock - goodbye lowering blocks."
Now there's something I didn't know! Let me know how you make out on that... I may be heading the same way... was looking for another truck's set that would do the same... I know Jeep YJ and F**d Ranger springs sit fairly close to flat or with a slight arch... Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
09-05-2010, 12:17 AM | #182 |
Jeff, what did it take to mount your rear bumper? Did you have to modify the stock rear bumper brackets? I have a rear bumper, but no brackets and I'm trying to see if I need to source some or just build some from scratch. Thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
09-05-2010, 07:01 PM | #183 |
From what I have read all the zq8 parts can be found on the extreme s10's including drop coils up front. I think they are like 1.5in drop coils. Also, large sway bars.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
09-07-2010, 10:00 AM | #184 |
Blue Jeep,
I used the stock bumper brackets and integrated them with my rear bed mounts - to kill two birds with one stone. I used what I had laying around; just a piece of 3 inch square tubing. Both the bed and the rear bumper brackets are bolted to the tubing. I will get you photos because it will be a ton easier to see the brackets than for me to try and explain them. They are just tacked at the moment, but you will get the idea. Jeff |
09-12-2010, 05:21 PM | #185 |
Thanks Jeff, I'll look forward to seeing how you did it and what I'm going to need to do for the same.
09-21-2010, 10:09 PM | #186 |
very helpful thread!
09-26-2010, 05:36 PM | #187 |
Making progress...still needs driveshaft, radiator and steering column.
11-06-2010, 02:58 PM | #188 |
jeff, how are you mounting the master cylinder, I was thinking of mounting mine under the cab since there is extra room using your body mounts
03-07-2011, 11:20 AM | #189 |
*****UPDATE******
Fired up the motor this weekend and man was that a kick in the butt. Rebuilt the motor myself, minus the machine work. It was almost like watching your children walk for the first time. Ok a distant second, but very cool. We also started setting the sheet metal (hopefully for the last time). I hope I've got all the bugs worked out. The truck should be driving by the end of the month. I'll let you guys know. Jeff |
03-07-2011, 12:14 PM | #190 |
Very Cool!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
03-07-2011, 01:31 PM | #191 |
Sweet! Congrats Jeff! Looking forward to that day myself!
03-09-2011, 09:29 PM | #192 |
Jeff,
Awesome to hear that you got the motor up and running. I was wondering what happened to you. Hadnt seen your thread updated in a while. Thanks for the offer on the fuel cap. I went with 1952ssr's idea of seperating the caps, still have to get the old cap and tear it apart. Might have to take you up on the offer if it doesnt work. Make sure you shot a video of your first drive and post it up. Im sure it will give a bunch of us some motivation. thanks again Brian
03-11-2011, 11:40 AM | #193 |
Thanks guys!
I appologize for the lack of updates, but life is currently kicking me in the teeth. My home computer died and my only access to the internet is while at work and the office filter stops me from posting photos. Truth be told, I would rather spend the money for a new computer on my truck. I know, priorities, priorities. Ok, back to the salt mine. Jeff |
03-11-2011, 02:38 PM | #194 |
Congrats on your progress Jeff!!!
03-20-2011, 10:55 PM | #195 |
SSN 706
Guess I'll copy your cab mounts. I'll might have to copy some other things as well. I really have no idea. Told ya I would get one of these trucks one day.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 03-20-2011 at 10:56 PM. |
03-21-2011, 09:39 AM | #196 |
Daverod,
I'm glad to hear you finally jumped in. Let me know if you have any questions. I don't know much, but will help out as much as I can. Jeff |
03-21-2011, 09:58 AM | #197 | |
my email is MrDude_1@FastGM.com (theres a _ between Dude and 1 that you cant see when its underlined) |
03-27-2011, 01:51 AM | #198 |
Nice build post. I am planning on going with a S10 frame on my 58. Very nice work.
Rich |
10-12-2011, 09:44 PM | #199 |
I have been following for awhile any updates?
10-12-2011, 09:56 PM | #200 |
Watching this one
Posted via Mobile Device |
