Old 03-19-2015, 04:14 PM   #176
rusty76
rusty76's Avatar
Re: Blake's 67 GMC stepside build
Looks good to me.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-20-2015, 09:47 AM   #177
reaper71
reaper71's Avatar
Moving on to the rear fenders...
Pic #1. Drivers side....This thing had a heaping pile of mud on it to cover up all the bad..here is a shot of the rot as well.
Pic #2. Shot of the holes someone drilled to pull a dent and then filled with mud!!!
Pic #3. After hammer & dolly work..
Pic #4. The busted up flange..
reaper71 is offline   Reply With Quote
Old 03-20-2015, 11:09 AM   #178
RockinKees
RockinKees's Avatar
Well, you got yourself some work now
This is easy for you!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 03-21-2015, 09:07 AM   #179
reaper71
reaper71's Avatar
Well I don't know about easy, but It was a challenge..
Old 03-24-2015, 09:41 AM   #180
reaper71
reaper71's Avatar
Pic #1. The inside lip for the rear fender. (the yellow portion marked out will be replaced)
Pic #2. Another shot of the rotted section (fuzzy picture sorry!)
Pic #3. More rot..
Pic #4. Busted up lower section needs help as well..
Pic #5. This was after all pieces cut out and all fixed..
Mark...
Old 03-24-2015, 04:00 PM   #181
RockinKees
RockinKees's Avatar
Nice work!!
I said it: easy
Cheers!! Kees.
Kool Guyz CC
Old 03-24-2015, 06:45 PM   #182
Advanced Design
Advanced Design's Avatar
Really nice work on the fender repair Mark. Looks good!
Advanced Design is offline   Reply With Quote
Old 03-25-2015, 04:50 PM   #183
rusty76
rusty76's Avatar
This was nothing for a man of your means...lol. Great work.
My build thread
Crossmembers CC
Old 03-26-2015, 09:38 AM   #184
reaper71
reaper71's Avatar
Thank you guy's!!!
I know at times (in the pictures) it all looks easy,but we all know in the real world it is not always as easy as they appear.
Pic #1.A closer look at the repair.
Pic #2. This is the lower section that was bad,template and new piece..
Pic #3. Here is the new piece ready for final fitting. If you notice it has flanges.
These will help with making the new piece more ridged and add strength to the lower section of the fender as well. (The flange also had holes in them for spot welds)
Pic #4. Tacked in place.
Pic #5. Finished repair..
Mark...
Old 03-26-2015, 01:33 PM   #185
RockinKees
RockinKees's Avatar
Nice repair, Mark, again!!
Cheers!! Kees.
Kool Guyz CC
Old 03-26-2015, 03:11 PM   #186
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
Nice job man. Wish my skills were that good.
FRANKENSTEINC10 is offline   Reply With Quote
Old 03-26-2015, 08:42 PM   #187
yj4000
yj4000's Avatar
Very nice indeed. Keep up the great work.
Ryan.
yj4000 is offline   Reply With Quote
Old 03-27-2015, 07:51 AM   #188
Advanced Design
And in the real world it usually takes longer than it appears. Nice work!
Old 03-27-2015, 09:38 AM   #189
reaper71
reaper71's Avatar
As usual Guy's Thank You!!!
Doug....You got that right Brotha!!! These things eat up time like M&M's
As far as the skill's go it's trial and error..We all learn from other people's ideas, magazine's,TV shows etc. (this site is a big help for new and old ways)
Things look easy in pictures but as I said before it is not always that easy!
A bit of advice, look at the problem and think about it, and what would be the best way to fix this. (sounds simple enough and really helps) Then come up with your game plan to achieve your goal. (and use the poster board to try out your idea, A lot cheaper than metal )
Old 03-27-2015, 09:56 AM   #190
reaper71
reaper71's Avatar
Pic #1. Just a 2nd view of the repair..
Pic #2. The holes that needed to be repaired.
Pic #3. Shot in Epoxy primer..
Pic #4. More Epoxy.
Pic #5. Then finally in High Build.
Mark...
Old 03-27-2015, 11:09 AM   #191
tim's68gmc
tim's68gmc's Avatar
great job on your truck.
check out my page http://67-72chevytrucks.com/vboard/s...d.php?t=659403
vehicle's I own 1968 gmc 3/4 ton camper special
1972 gmc jimmy
1972 Chevrolet nova
1947 ford 1.5 ton dully
1997 f-350 1 ton
2007 Chrysler 300 with hemi
tim's68gmc is offline   Reply With Quote
Old 03-27-2015, 06:47 PM   #192
FRANKENSTEINC10
My problem is the lack of "spare" panels. :-( once I get my stock up I can start practicing.
Old 03-30-2015, 07:51 PM   #193
reaper71
reaper71's Avatar
Thank's Guy's!!
Old 03-31-2015, 09:41 AM   #194
reaper71
reaper71's Avatar
Pic #1. The rear fenders after I coated the backsides with Rust Encapsulator
Pic #2. Drivers side during paint stripping.
Pic #3. Drivers blinker opening being fit for fill panel.
Pic #4. Another view..
Pic #5. This was taken after Epoxy,high build and Eastwood were applied.
Mark...
Old 03-31-2015, 06:11 PM   #195
Advanced Design
Looks good Mark! I still need to stop by a hardware store to get some of those magnets.
Old 04-01-2015, 09:53 AM   #196
reaper71
reaper71's Avatar
Thank's Doug! The magnets really help, and come in several sizes. I also use a bolt 10/32 and a nut followed by a nyloc nut on the end this way you have something to grab onto.
Pic #1. Passenger side rear with guide coat ready for blocking.
Pic #2. Drivers ready for blocking.
Pic #3. Passenger side door during the blocking stage. (the dark spots are the low areas)
Pic #4. Another view of the door and more low spots shown here (dark spots) these will need some TLC...
Pic #5. The upper section after blocking reveals some low spots as well..
It's amazing how beat up these areas are for the inside of a door!!!
Old 04-01-2015, 11:47 AM   #197
RockinKees
RockinKees's Avatar
Looks good Mark!
You're a true Craftsman!
Cheers!! Kees.
Kool Guyz CC
Old 04-01-2015, 02:08 PM   #198
swamp rat
swamp rat's Avatar
Great work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-06-2015, 09:35 AM   #199
reaper71
reaper71's Avatar
Kees and Swamprat Thank you!
Been really busy with other projects (house remodel) so have been away from the shop a bit...
Pic #1. Here is another view of the door. (more dark areas showing the low spots)
Pic #2. This was after more blocking and clearly shows how badly wavy the bottom is.
Pic #3. After the entire door was blocked reveals alot of work ahead...
Pic #4. 1st round of filler..
Pic #5. 2nd view..
Till next time
Mark...
Old 04-06-2015, 12:33 PM   #200
Advanced Design
Great attention to detail...doing the door bottoms. Good luck with the house remodel!
