Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-22-2012, 01:59 AM   #201
dinnut
dinnut's Avatar
Re: post latest 1/4 and 1/8 mile times and 60ft.
I went out to sealy with my newer setup today. I was happy with the results . I switched out to a set of 781s with big valves. Put a weiand stealth intake and 850 holley on there. I'm running a 3200 rpm revmax converter . First run out I went 12.78@105.7mph. 1.92 60 foot. Quite a bit better Than my last time out!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 04-28-2012, 10:49 PM   #202
bigboybodry
bigboybodry's Avatar
last night the family and I took the old truck out to the strip for the first time with the new engine/chassis setup. I decided to run just on motor because of the new engine,trans,suspension,brakes etc... and it did ok for the first time out. left on foot brake it started to transfer and broke loose clicked it off at the 1/8 mile to check the plugs etc....
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 04-29-2012, 03:48 AM   #203
flamingbig10
6.0 powered square
flamingbig10's Avatar
my first run ever 1/4 13.7 at 98 with a .532r/t and a 60ft of 2.18 with a bolt on and cammed 6.0 with a stock 4l80e and street tires my third run I ran a 13.6 but I lost my time slip, 4th run did a light burnout had to wait forever for the car in front of me took off side ways and coasted down the track at a 16.8, next run out I will have a 3600 stall, a better tune, and drag radials hopping for a low 13
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-29-2012, 07:25 AM   #204
69trk
69trk's Avatar
Nice truck!!!!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 06-26-2012, 12:33 AM   #205
flamingbig10
6.0 powered square
left lane on a 1200rpm launch
Aaron
Old 07-14-2012, 01:01 PM   #206
85_prairieboy
85_prairieboy's Avatar
New personal best
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 07-14-2012, 03:11 PM   #207
flamingbig10
6.0 powered square
new personal best running a modded wrx
Aaron
Old 07-14-2012, 08:35 PM   #208
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I think if you could get your 60' down to a 1.6 you should run a 11.5-6 easy with that MPH.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 07-15-2012, 12:51 AM   #209
85_prairieboy
Yeah the track was pretty bad. I couldn't get traction off the line. It was a street legal night so there was no traction compound down. But I was pretty pumped. It was almost a second faster just from a gear swap and bigger tires
1980 Z28 Camaro
Old 07-20-2012, 06:42 PM   #210
Boostedbowtie
Got better video of my truck .
Boostedbowtie is offline   Reply With Quote
Old 07-28-2012, 12:24 PM   #211
85_prairieboy
Tried again with linelock and transbrake.
With hood on:
60' 1.71
1/8 7.46
1/4 11.72
mph 114
Took my hood off:
60' 1.63
1/8 7.32
1/4 11.58
mph 114
Time for a roll cage now
1980 Z28 Camaro
Old 07-29-2012, 03:28 PM   #212
Super73
Super73's Avatar
Looks like it is time to also update your signature. Congrats!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-30-2012, 10:13 PM   #213
85_prairieboy
Thanks! Signature updated
1980 Z28 Camaro
Old 07-30-2012, 10:16 PM   #214
85_prairieboy
You were right C-10
1980 Z28 Camaro
Old 07-30-2012, 11:22 PM   #215
68 C-10 KID
Mean Green
That truck of yours honks on good on the big end of the track.. Congrats on the new times. Have fun be safe.
AKA MEAN GREEN.
Old 08-19-2012, 03:48 PM   #216
Super73
Super73's Avatar
New bests for me
418ci LS motor running E48 (91/E85 mix)
Power Glide trans
4.56/30" Drag radial
Motor Pass
60' = 1.539
330' = 4.298
1/8 = 6.673 @ 103.984
1000' = 8.749
1/4 = 10.54 @ 122.293
It is laying over on the top end and the converter is "too tight" for motor. But not bad for first weekend out shake down.
100 hit.
60' - 1.521
1/8 - 6.301 @ 112.336
1/4 - 10.216 @ 111.814
I left on the trans brake on motor, reach up and armed the bottl. N20 is on a WOT switch so it came on right away. I was out of gear well before the 1,000' mark.
Old 09-04-2012, 02:35 PM   #217
bigboybodry
Originally Posted by Super73 View Post
New bests for me
Power Glide trans
Motor Pass
60' = 1.539
330' = 4.298
1000' = 8.749
100 hit.
60' - 1.521
rock on brother that's awesome!!!!
Old 10-06-2012, 11:08 PM   #218
RICKSRAT
RICKSRAT's Avatar
Well finally got truck out to make a nitrous pass. Made a motor pass to check out new rear coilover spings (200# -> 150#) from previous trip,went a 10.70@122 . First nitrous pass came off the transbreak and shifted way early to second gear. Will be moving transbreak button to steering wheel from shifter . Second nitrous pass was ok but not wanting to shift early was a little late as you see in the video. Looks like it sat the front tires down just pass the 60' mark with a 1.35 60'. Best pass of the night was a 9.82 @ 133.61 on 1 stage. Now to finish wiring the second stage and see what it will do. Also meet Dinnut and some his buddies, good to meet you Dinnut.
http://youtu.be/sI0qQfgYxr4
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30
Old Motor: 60'. 1.43
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
RICKSRAT is offline   Reply With Quote
Old 11-03-2012, 09:07 PM   #219
flamingbig10
6.0 powered square
12.9 on street tires
Aaron
Old 11-14-2012, 02:19 PM   #220
bigboybodry
foot braked the truck and shot 150hp on it for the first nos pass. It picked the tires up and unloaded. upon inspection later I found a dent in the rear differential cover. It looks like the panhard bar has been hitting the cover causing the rear to unload.
Old 11-15-2012, 09:00 AM   #221
Super73
Super73's Avatar
Lookin good. Should really move out once you find and fix the little issues!
Old 11-20-2012, 12:49 PM   #222
tn farm truck
I'm new on this forum. Thought I would post up my #'s
The truck is a 72 step side factory suspension sbc with one of my 700 r4 trans and a 4.10 9inch rear with 315 mt drag radials. It's a street driven truck.
60' 1.36
1/8 6.38
Mph 106
Going to put a Scott's hotrods front end under it after the first of the year to help get ride do some weight. Truck weight is 4200 with me in it. Will post picks latter. The truck was in oct. 08 HR mag we ran pump gas drags and was lucky enough to make the mag. But got put out first round.
tn farm truck is offline   Reply With Quote
Old 11-20-2012, 01:13 PM   #223
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Nice times tn farm truck. would like to know more bout you engine combo
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 11-20-2012, 01:36 PM   #224
Super73
Super73's Avatar
Definitely impressive at 4,200lbs. Looks like you have a low 10 to high 9 in it.
Old 11-20-2012, 02:24 PM   #225
tn farm truck
Thanks guys. the truck has a dart little m block. it is a 434cube sbc. it has brodex ik200 aluminum heads and a motown intake. Barry grant 750 might demon 10.5 to 1 comp. solid roller bullet cam. MSD billet dis. and a digital 6 box. going to convert to e-85 in a month. it has an NX system with edlebrock controller. I have the 250 pills but spraying 75%. So there is still a lot left in the truck especially when we change to e-85. The trans is my stage 3 700r4 trans. I will post a video and pics of the truck and the 6.42 pass some one video at my last race. the truck should run 6:15 when we get it dialed in with the 250 shot and hoping for high 5's when we convert to e-85. Were also running a 10 point cage mild steel. Oh and the truck is pearl white with a spare tire on the side and yes I'm(to the younger croud) an old man
