10-02-2019, 06:45 PM | #1 |
Holland Michigan Mechanic and Inspector
Trying to buy a 69' Blazer in Holland, MI from another state. Want to pay mechanic and/or Blazer expert (local fanatic encouraged) to inspect and test drive before I buy and ship. Referrals much appreciated!
10-02-2019, 07:58 PM | #2 |
Re: Holland Michigan Mechanic and Inspector
check numbers on title and vin numbers on truck, see what is required in your state to register. California has some weird requirements, so check with DMV
Welcome aboard
10-02-2019, 10:15 PM | #3 |
That, sir, is the understatement of the century, and on many fronts......!!
-Bruce 1971 K5 Blazer 4WD |
10-03-2019, 09:52 AM | #4 |
Guest
Posts: n/a
Matt, forgot to mention the emissions label issue when we talked. There is a good active discussion on the Blazer forum now. I will call you later to discuss. Martin
10-03-2019, 10:09 AM | #5 |
Your lucky big forums base in that area
10-03-2019, 11:12 AM | #6 | |
https://www.dmv.ca.gov/portal/dmv/de...orms/reg/reg31 see section 9 for emissions '68 and up and section 6 for FMVSS requirements '70 and up depending who you know, this may be very difficult if missing when you have to go through a CHP station.. besides the 2-3 month backlog for appointments.. good luck!
I started out with nothing - and I still have most of it |
10-03-2019, 07:31 PM | #7 |
Brought my '71 in from Montana last Thanksgiving. Went to AAA and was out in about half an hour (older lady was pretty sharp and asked a lot of questions, but all in all it was pretty easy). Not sure if I missed a deadline on the req's but this may be an option worth looking into. Don't know if I have the label or not (will have to go look later).
Good luck!
10-03-2019, 10:46 PM | #8 |
Guest
Posts: n/a
My AAA guy who was inspecting my out of state CO vehicle--I swear we were outside for at least 20 minutes--him checking and double checking my VINs and double and triple checking the emissions sticker. I'm thinking great, I got the most fastidious guy who ever worked for AAA checking my rig out--I would have killed for the don't care DMV folks. Anyway, it all worked out but geez, I'm registering an old Jimmy not a nuclear sub.
10-04-2019, 10:14 AM | #9 |
I think the gal I got thought it was a pretty cool rig and remembered them, so she spent extra time. She knew her stuff and did have a lot of questions, but I just told her it was an old rig, I just got it, and that I did not know a whole lot about it. It is kinda ridiculous how much poking around they do and what they expect to find after nearly 50 years!
10-04-2019, 01:08 PM | #10 |
Carpe manana
Clarify this for me. In CA do you need any emissions decal (i.e. non-CA emissions) or the CA specific emissions decal? It wouldn't take much effort to procure and place a non-CA emissions reproduction decal on a truck to be registered but the CA specific examples aren't available.
10-05-2019, 01:04 AM | #11 |
Guest
Posts: n/a
Pete, am pretty sure you just need the fed decal and I agree regarding a reproduction. Matt, the OP (is a fellow partner in my firm) is passing on the MI Blazer so just wanted to pass that on.
10-05-2019, 05:55 PM | #12 |
wow, that is pretty stiff. I'm about to register my jimmy from nevada to california and i did not realize how much effort there is in doing that.
Tags |
#inspection, #mechanic, #michigan |
