11-04-2005, 05:42 PM | #1 |
Stripped door bolt hole, now what ???
One of the bolts must have had a burr on or something, but when I removed the hinge bolts from the driver door, one of the nut things and the bolt stripped out taking most of the threads out of the door nut on the top inside one, the single one of the three, of course. Are those nuts replaceable or how would you fix ??? Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
11-04-2005, 06:10 PM | #2 |
Re: Stripped door bolt hole, now what ???
Maybe a heli-coil would work??
"You can take the man out of PA, but you can't take PA out of the man" |
11-04-2005, 06:13 PM | #3 |
Tap it for a larger bolt?
11-04-2005, 06:15 PM | #4 |
get a longer bolt and put lockwasher and nut on it
11-04-2005, 06:23 PM | #5 |
I agree with HeavyD...Helicoil.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
11-04-2005, 11:59 PM | #6 |
I think there may be some threads left in the back of the nut, If I put a bolt though from the back and maybe loctite it and use that as a stud , will that hit anything assuming bolt is not to long of course, Ya think that might work ?
11-05-2005, 07:11 AM | #7 |
It is a little bit of work, but I retapped the door nut to 7/16-20. For the bolt, I turned down the shank to 3/8 diameter x 3/8 long under the head, (to give it clearance for adjustment). I then ground the hex on a belt sander to fit a 9/16 socket. The hinge slot had to be opened up slightly to clear the 7/16 threads.
It looks good and works well. Jim |
11-05-2005, 10:32 AM | #8 | |
My thoughts anyway. When mine did this, I tapped it out to the next size. |
11-05-2005, 12:08 PM | #9 |
When the inner door plate drop down into cabs door post hollow....thats where the fun begins. How you fix that without cutting the cabs forward door post open?
06-21-2012, 10:16 PM | #10 |
Great suggestion! I just stripped one of my upper nuts and one other was stripped to begin with. Best laid plans rebuilding hinges. After putting the door back on and realizing the mess I am in.....I started looking at skin removal...plug welding nuts and the like. To heck you say.....put a nut and washer on a longer bolt----DONE.
06-22-2012, 12:03 AM | #11 |
Check the paint and body forum, there is thread about this there twoards the top right now.
