Old 04-04-2015, 09:11 PM   #1
dafrp65
dafrp65's Avatar
68 3rd seat belt point mount location?
My interior is upholstered and I would like to find the plug on the first try.
dafrp65 is offline   Reply With Quote
Old 04-04-2015, 10:28 PM   #2
sy2767
sy2767's Avatar
Re: 68 3rd seat belt point mount location?
Im not sure if mine is stock or not but it uses the same mounting location
as the passenger and driver.
sy2767 is offline   Reply With Quote
Old 04-05-2015, 08:15 AM   #3
dafrp65
dafrp65's Avatar
What I need is the dimensions for the location of the upper bolt mount for a three point seat belt.Mine are under upholstery and I would like to hit the hole the first time.
Old 04-05-2015, 08:28 AM   #4
dads71bigblock
If its cloth try using a needle to find it.
dads71bigblock is offline   Reply With Quote
Old 04-05-2015, 10:20 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: 68 3rd seat belt point mount location?
Most of them I have seen have a plastic cap over them. Maybe hard to find with the needle trick.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-05-2015, 10:26 AM   #6
smerkey
By pressing hard with your finger and moving it around the area I would think you could either feel the caps or the holes (whatever the case may be) through the fabric. They're not super small.
smerkey is offline   Reply With Quote
