Old 05-01-2013, 09:06 PM   #251
Mayo
Cool Truck
Mayo's Avatar
Re: 8 lug wheels - what's on YOUR truck?
I have always thought those H2s looked nice
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 05-01-2013, 09:26 PM   #252
Scott>72-GMC
Scott>72-GMC's Avatar
What mine came with from po. Stuck with them for now
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 05-11-2013, 06:24 PM   #253
-Greg72
-Greg72's Avatar
Originally Posted by K20chevy View Post
Dodge actually has 17x7, 17x7.5 and 17x8 stock steel wheels with the 8x6.5" bolt pattern. The only problem is that they have huge backspacing. I think about 6"! So on the old trucks youŽd have to use spacers OR maybe you could "re-center" them for a little less backspacing.
The coolest would actually be to use the old center caps on these wheels somehow....
I'll take another look for Dodge steelies on eBay or wherever.
In my application, I actually WANT a lot of backspacing. (5-1/2" to 6" would be fine). Ideally, I really want a wider wheel....something in the 11"-12" range, so even if I find a Dodge wheel it will probably end up hacked apart to graft the center into a wider barrel.
Thanks for the leads...
-G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 05-11-2013, 09:58 PM   #254
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Originally Posted by FirstOwner69 View Post
The H2 wheels and Chevy caps will be going on mine when I get to that point. I'll have a little different looking cap though. I'm trying to mimic the original hubcaps.
Looking good. What did you finally end up using on your caps?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-11-2013, 11:30 PM   #255
FirstOwner69
FirstOwner69's Avatar
I ordered some of these (http://www.ebay.com/itm/4-Chevy-Bowt...#ht_486wt_1043) in 3.5" but didn't care for the look. I found that Chevy Malibus from the early 2000s (late 90s?) have a blue bowtie in the trunk emblem that just covers the stick on on those I ordered, and most of the Malibus have the silver around the bowtie. I carefully pried them from the trunk emblems and glued them on the eBay emblems (after installation on the cap) with a light coat of Goop adhesive. I actually have only done the one in the picture. Since then, we were burglarized and the set of caps was stolen along with a set on like new 2001-2007 Silverado HD alloy wheels. The eBay seller also sells just the black discs for half the price, but the blue outline bowtie helps center the Malibu bowtie.
Here's a better pic of just the modified cap:
FirstOwner69 is offline   Reply With Quote
Old 05-14-2013, 07:43 PM   #256
Critterman71
Critterman71's Avatar
all of you guys out there with newer GM 8 lug rims on their trucks how did you get the center cap to stay on the new style lug nuts did you change rotors? I have 2005 2500 hd wheels and caps and the new style lugs with the threads on them but the black covers in the caps will not reach the lug nut for some reason can any one help and any one have pictures with the wheel off and with it on and no cap by chance. thanks
Critterman71 is offline   Reply With Quote
Old 05-15-2013, 06:55 AM   #257
OhioDan
OhioDan's Avatar
Cool Re: 8 lug wheels - what's on YOUR truck?
Do you have a Dana60 rearend? If so, sounds like you're having the same problem I had? Your center cover won't go on because of the axle hub. I used 1 1/4" spacers on mine to get the rim out to where they would fit. Have since found out that I can get the centers for a dually set up that will work without the spacers. The spacers have been on for 3-4 years with no problems. pic of spacers below. Just bolt them on, and then use the studs on them to bolt your rims on.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-15-2013, 07:40 AM   #258
OhioDan
OhioDan's Avatar
Here's a pic of them bolted on.
Old 05-15-2013, 09:53 AM   #259
RogerKoop
RogerKoop's Avatar
If you are looking for factory steel wheels try Stockton Wheels in Stockton CA. I had a set made to my specs. Turned out great.
Roger Koop
RogerKoop is offline   Reply With Quote
Old 05-15-2013, 05:45 PM   #260
Critterman71
Yep its a dana 60 and you are correct. I have the rear figured out I can go three ways to make them fit spacers, dually caps or the route i started and probably the most expensive is longer studs to accommodate a special lug that a local machinist can make me to fit the wheel but the cap will still hit the axle cover plate. so the dually caps or spacers is the better way on the rear for sure. Now I need to figure out the fronts I have the stock disk brake set up and once the wheel is on the lugs are tight the black cap covers that hold the cap to the rim wont reach, I can get one or two started but wont tighten up they pop off so I am about 3/4 of an inch or so shy from making them work on the front and need ideas for that if any one has any. Thanks OhioDan for the info so far much appreciated you to Roger if I cant get the look I want I will go the the steel wheels for sure and will look uo Stockton Wheel for sure.
Old 05-16-2013, 11:25 AM   #261
nate_g_2003
nate_g_2003's Avatar
Centerline Blackfoots in 16.5"...were on the Burb when I bought it, have been on it since the 90s. Not a bad wheel, but I want something different, that will be easier to get tires for.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 05-17-2013, 08:52 PM   #262
Spartan
Spartan's Avatar
The pic in my avatar is what I'm running for now. It's sideways, I know, but I just pretend it's climbing a really steep incline...or as special-k once said it looks fine if you're eating a taco. It's going to get 16x7 and power kings eventually.
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 06-02-2013, 08:55 PM   #263
Critterman71
bought dually caps today at local swap meet brought them home and they will no not work either they are deep enough to let the axle cover fit inside the cap but the lug caps that screw on to the lug nuts to hold the cap on will not reach the lug nuts that is the same problem I have on the front with the stock 2005 3/4 ton cap I love the 2005 -06 3/4 ton wheels but this is getting crazy trying to get them to fit. If anyone can help out some more let me know
Old 09-13-2013, 06:55 PM   #264
dubds10
Stalker Nate
Bump for 8 lug guys. I'm trying to find the dually caps from a mid'90s Chevy to put on the steelies I have. One found set and it sold fast. Hoping to find another set or I'll just run spacers out back, but caps would be cheapest.
Nate
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 09-13-2013, 07:58 PM   #265
JointTech
JointTech's Avatar
i left the hubcaps off mine.
AE Series 018 20x9
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 09-14-2013, 11:25 AM   #266
dubds10
Stalker Nate
Old 10-31-2013, 11:59 AM   #267
NASTY-LSX
Originally Posted by cleszkie View Post
I run 16.5x10 steelies with the 3/4 ton dog dish caps for that rugged, yet stockish look. Took me a while to put together a full set of those rims.
Does anyone know if these steel wheels are being sold as repops yet??
I have a 85 K20 and do not want to go over 17 or bigger wheel.
NASTY-LSX is offline   Reply With Quote
Old 10-31-2013, 12:32 PM   #268
Devillusion
Devillusion's Avatar
I know you can get them in 16s, and would highly recommend it as you normally pay through the nose for 16.5 tires and selection is minimal.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 10-31-2013, 01:00 PM   #269
K20chevy
K20chevy's Avatar
I was thinking about running these, as they kind of look like the old mags.
http://www.hotrodhanks.com/imagesProducts2/16358.jpg
The old dually steel wheels also had oval holes, but 4 insted of 5. Maybe powdercoated white with OEM hub caps would make them look kind of vintage too!
What do you guys think?
UNLESS of course anybody knows of a company building 18" or 20" steel wheels, or aluminum that look like the OEM 16" steel wheels and take the OEM hub cap! If anybody hears about anything like that, LET ME KNOW!!!!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 10-31-2013, 04:31 PM   #270
Extended72
Not wanting to hijack the thread but I am looking for advice of what vehicle I can do a swap out of rear axle that has disc breaks positraction and something that doesn't have to be cut on to make it work. I have a 72 c20 and want to stay with the same wheel package that I already have. Any advice or suggestions are appreciated.
Please pm me if anyone has any info.
Robert
72 C20 custom extended cab short bed.
http://i1320.photobucket.com/albums/...ps0be39e4c.jpg
THE ONLY THING HOLDING ME BACK IS FEAR AND COMMON SENSE AND OF COURSE MONEY.
Extended72 is offline   Reply With Quote
Old 10-31-2013, 04:47 PM   #271
NASTY-LSX
Robert
If im correct, you can get an aftermarket disc brake kit. Just get a posi carrier!
Old 10-31-2013, 06:59 PM   #272
Critterman71
Extended72 there are kits out there for the C-20 I retrofit my 71 C-20 Longhorn with disc brakes out back for less than 500.00 with quality parts. the biggest trick on the C-20/30's are the rear hubs they rotor has to go on the back if the hub so when you do the job or need to turn the rotors you have to remove the hubs and that is time consuming but worth it for sure.
Old 03-02-2014, 08:33 AM   #273
Edmond
Edmond's Avatar
Originally Posted by Critterman71 View Post
Hey I have mid 2000's factory 8 lug aluminum wheels of of a silverado 2500 and the look great they are 16 inch and can hold a 265 75 16 tire no problem I will try to post a pic of my truck to show you what they look like center caps work great also just have to use the new style lug nuts with the threads on the outside to hold the cap on
Just wondering, Did the hole for the axle hub fit right away or did you have to make it bigger?
My truck has the ho52 Eaton Axle.
Thanks.
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
Capelle a/d IJssel,
The Netherlands
Edmond is offline   Reply With Quote
Old 03-02-2014, 02:40 PM   #274
I have 8.25 & 9.75 -16.5 steelies but not looking like a truck for them for a while. Can't go wrong on a C/20. Guys never worried with hubcaps,either. I remember black wheels. They look great with chrome lugs
Old 03-02-2014, 03:25 PM   #275
terry b
terry b's Avatar
Heres mine.
terry b is offline   Reply With Quote
