04-17-2012, 08:56 PM | #1 |
Junior Member
Fan shroud holes won't line up
Any ideas? Here are some pics.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 04-17-2012 at 09:03 PM. |
04-17-2012, 09:16 PM | #2 |
Re: Fan shroud holes won't line up
Upside down???
04-17-2012, 09:25 PM | #3 |
Loosen the radiator hold down brackets and then try to bolt the shroud...maybe that will give you a bit of wiggle room. Then tighten it all up.
1971 C-20 350/350 |
04-18-2012, 10:29 AM | #4 |
Restoration Virgin!
If that's a sbc fan shroud, the bottom of the shroud sits in clips....have you simply tried to lift it up out of the clips some....that's what I had to do to get it to line up
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-18-2012, 10:38 AM | #5 |
C/10 junkie
I think a combination of loosening the rad hold brackets and lifting the shroud up a little should do the trick. Good luck.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
04-18-2012, 10:38 AM | #6 |
Junior Member
I ran out of daylight last night. I am thinking it may have to do with me replacing the rubber in the hold downs. I already trimmed them in half but maybe some more trimming is necessary.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
04-18-2012, 10:50 AM | #7 |
04-18-2012, 11:54 AM | #8 |
Are the brackets correct for the radiator, maybe a larger 4 row with stock brackets?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-18-2012, 12:41 PM | #9 |
This happened to me when I installed a 4-row radiator in place of a 2 or 3.
I had to get new "cups" for the bottoms and rubber for top and bottom. When I got done nothing lined up. I ended up NOT using the factory clips on the bottom. Down there I have cable ties. (You trailer queen folks probably are worried about people looking at the bottom of the fan shround and should look for a different solution there). Using the cable ties allowed some play in the top. For the top I made little brackets out of sheet metal. (queens will probably want to paint those black.) Those little "brackets" and cable ties have been in place since May of 2003 with no cooling issues or fan rubbing problems.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-18-2012, 02:05 PM | #10 | |
Junior Member
04-18-2012, 03:52 PM | #11 |
04-18-2012, 04:15 PM | #12 | ||
"I ain't nobody, dork."
You have the 2-3 row upper brackets and what appears to be a 4 row radiator. You need the longer upper brackets and rubbers.
Make sure you also get the larger lower brackets and rubbers too. Gary
04-18-2012, 04:31 PM | #13 |
Junior Member
This is the same radiator and brackets that were with the truck when I got it and everything lined up perfectly. These are 4 row brackets a have some others to compare them to. I only changed the shroud.
04-18-2012, 07:09 PM | #14 | ||
Thats odd... shoulda fit just fine.
Gary
04-19-2012, 10:38 AM | #15 |
Junior Member
Ok had A minute or two to take another look last night. It must be the shroud. Is there a special shroud for a 4 core radiator with a small block? If you look at the picture below there is no way the gap between the hold down and the shroud can fit because the shroud is flush against the radiator.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 04-19-2012 at 04:22 PM. Reason: punctuation |
04-19-2012, 11:29 AM | #16 | ||
Is it an aftermarket shroud? Or OEM?
I bought a used OEM shroud because of all the fitment issues with the aftermarket shrouds. Gary
04-19-2012, 11:53 AM | #17 | |
Junior Member
Based on mrein3's post it looks like the fan shroud for a 4 row must be different. I trashed my other one because the ear completely broke off. I should have save it for comparision but I did not expect a problem.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 04-19-2012 at 11:55 AM. Reason: add info |
04-19-2012, 12:28 PM | #18 |
C/10 junkie
The one that mrein3 posted looks to be a 4x4 shroud which is deeper but should mount up the same.
04-19-2012, 12:48 PM | #19 |
Junior Member
I didn't notice that but that means it has to be for a small block.
04-19-2012, 02:00 PM | #20 | |
I don't know if all big blocks got 4-rows or if they used the same shroud as a small block. However to me it appears that there is a "4-row" shroud and a "2/3 row" shroud. Perhaps the parts guys that go through so many of these have seen a difference.
04-19-2012, 03:07 PM | #21 |
C/10 junkie
Ok I have 2 different types of fan shrouds, one 4x4 and one not. I just went from a 3 core to a 4 core, still have the 292, but in the next day or so I will try both shrouds and see if either one fits.
04-19-2012, 03:12 PM | #22 |
Junior Member
Let us know. I have seen different aftermarket ones listed for heavy duty radiators. I have a BB shroud wonder if it will work?
04-19-2012, 03:17 PM | #23 |
C/10 junkie
My shrouds are both oem but try the big block shroud and maybe we can make a faq out of this thread. I will be sure to take plenty of pics.
04-20-2012, 10:40 PM | #24 |
C/10 junkie
Ok here are the two shrouds that I have
And here is the 4 core radiator that I installed last weekend I was able to install the smaller shroud and it lined top and bottom with no problems, sorry for the crappy pics I was by myself and only had my cell phone but you GW the idea One thing I did notice is there is this piece on top of the radiator and ifs didn't pull the shroud up over the piece the tabs wouldn't be close enough to bolt up. Maybe that's part I'd the issue. I hope this helps. Posted via Mobile Device
04-20-2012, 10:41 PM | #25 |
C/10 junkie
The 4x4 shroud won't fit with the six cylinder still in it.
