08-14-2019, 02:52 PM | #1 |
SPID question
Guys
As i strip my cab trying to get ready for paint, How do protect the SPID from getting either painted over or just scraped off Or do I just remove it and get a new one made ( from board member) and up-to-date it with the extra options I have add to the truck so far?
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
08-14-2019, 05:31 PM | #2 |
70+ ( Old Skool Club )
Re: SPID question
If you are going to paint the truck the same color remove the original glove box door and put it back on when done. If changing paint color still remove original glove box door then get one from a wreck and paint it to match and order a new spid from outintheshop.com, board member Chipflyer, and put the new spid on the repainted glove box door and keep your original safely tucked away intact. I'm doing exactly this only I bought a chrome glove box door and am spraying the middle wrinkle black and leaving the chrome outer lip as it will match the gauge surround.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-14-2019, 07:55 PM | #3 |
Re: SPID question
Save your original glove box door so you can prove what it was originally and paint another one to match . If you need one Im sure I can send you one .
08-14-2019, 08:03 PM | #4 |
Re: SPID question
This is timely as I was planning to ask to same question. Thanks for the new glove box door idea!
08-14-2019, 09:37 PM | #5 |
Re: SPID question
I always swap doors on trucks with SPIDs that I want to preserve when painting or chroming. I still have a few as momentos
