12-29-2019, 08:27 PM | #1 |
V8 np435
Anyone running this combo in their truck? Its in the v8 position and the high hump doesn’t work, looks like I need to use the I6 location for the engine mounts and move the trans crossmember back accordingly.
Not a common combination, the trans was previously behind a GMC 305 V6. Thanks, Jon
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
12-29-2019, 10:07 PM | #2 |
Re: V8 np435
I have the Big block and NP435.
Motor mount location shown here.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA Last edited by Astro-Balls; 12-29-2019 at 10:23 PM. |
12-29-2019, 10:30 PM | #3 |
Re: V8 np435
Rectangular hole in the high hump?
12-29-2019, 10:46 PM | #4 |
Re: V8 np435
Yes,High Hump With rectangular hole.
Here is a pic before I install the shift boot.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
12-29-2019, 11:00 PM | #5 |
Re: V8 np435
Mine is further back in the flat portion of the cover. I’m betting I’m going to need to move the engine. Thank you for the pics!
01-01-2020, 05:56 PM | #6 |
Re: V8 np435
Engines now in the I6 location(V8 stands) and the high hump still won’t work, this engine and trans was in my C3500 but had been relocated in the frame after the V6 wore out, I’m wanting it in the right spot...hopefully someone on here has a V8/NP435 to confirm and tell me if I need the high hump like Astro’s
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback Last edited by projectking; 01-01-2020 at 06:30 PM. |
01-02-2020, 12:33 AM | #7 |
Re: V8 np435
Post some pics of your trans and bell housing, Engine mounts.
01-22-2020, 12:34 PM | #8 |
Re: V8 np435
Here are pics like you requested.
I figured I should respond in your thread and not the other one so that if someone else has an issue they can find the answer easier. My T-Hump looks just like the one that the guy with the big block posted. Looks like it's in the front holes. If you need pics of the transmission crossmember let me know and I can get those, too. Maybe you need a different bellhousing or something. I can get any pics you need!
1968 GMC C2500 Long Bed Fleetside |
01-22-2020, 12:45 PM | #9 |
Re: V8 np435
Thank you! I’ll move it back to the front holes and track down a square hole cover like the one you guys have. My trans was bolted to the crossmember in the front position. I appreciate the help!
01-22-2020, 01:22 PM | #10 |
Re: V8 np435
No problem! It seems to me like the NP435 isn't a very popular transmission, so if you ever need anything let me know. I'm not an expert by anyone's definition, but I had a heck of a time working with it during my engine swap. Good luck finding a high hump!
01-22-2020, 01:39 PM | #11 |
Re: V8 np435
Worst case it will get a 2wd 4 speed hump with the larger hole(mines a ‘67 small oval). It seems like a better geared trans compared to a 465 is why I decided to run it. Do you have any idea what flywheel you have?
01-22-2020, 02:25 PM | #12 | |
Re: V8 np435
Here are the parts I used as listed on Rock Auto. Not sure how to post a link to just the one part, but you can search the part number in the brackets and it'll come up. Flywheel - PERFECTION CLUTCH 506504 {#3991469} - $79.99 Clutch Kit - PERFECTION CLUTCH MU90911 {#90681} - $65.79
01-22-2020, 02:27 PM | #13 | |
Re: V8 np435
01-22-2020, 02:36 PM | #14 |
Re: V8 np435
I would not waist time on a NP435. The Sm 465 is a much better trans.
George |
01-22-2020, 02:50 PM | #15 |
Re: V8 np435
No thanks, I like having a useable 1st gear.
01-22-2020, 02:51 PM | #16 |
Re: V8 np435
What was the PN on your old one, if you still have it?
01-22-2020, 03:07 PM | #17 |
Re: V8 np435
I don't have it anymore, but it looked to be the original flywheel based on age and it was a GM part. The cracks and valleys were kind of scary; as soon as I got the new one and verified fit, it went in the trash.
01-22-2020, 03:37 PM | #18 | |
Re: V8 np435
Thanks again for your help/info!
01-22-2020, 03:50 PM | #19 |
Re: V8 np435
Any time, if you ever need anything else give me a shout!
