Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 03-04-2012, 02:38 AM   #1
LowGT
LowGT's Avatar
68 LWB 250/3spd
I'm almost afraid to ask because I know the 6's don't bring as much as the 8's, but I just did a lot to this truck and curious what you all think it's worth.
In the past 3 months I have:
power steering w/ correct pump brackets, new lines
converted to power disc front (new calipers/rotors/bearings etc)
5 lug conversion in rear with ECE shafts
New rear shoes/hardware/drums/cylinders
Added sway bar w/ new bushings
Complete suspension/steering overhaul(springs, shocks, tie rod ends, control arm bushings, etc.... kit from LMC)
Engine gasket kit installed including rear main
rebuilt carb
new fuel pump
skip white HEI
new clutch/pressure plate
new u-joints, carrier bearing, driveshaft balanced
new door felts
Lots of little things replaced that i can't remember
Only thing that doesn't work is factory radio
65 SWB BBW - 283, TH400
LowGT is offline   Reply With Quote
Old 03-04-2012, 01:05 PM   #2
sharpie1972
Re: 68 LWB 250/3spd
Nice truck! I would say in the 5-7k range depending on the quality of the body and paint work. I like the sound of a six popper! Sharpie
sharpie1972 is offline   Reply With Quote
