Old 01-10-2021, 07:35 AM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Melling Oil Pump 10778C Pros & Cons...
Finishing a rebuild on a 439ci BBC (race motor)...Just wondering if anybody has used this pump? This motor is a balanced 3.76" stroked solid lifter 8000 rpm motor...Do I "need" this anti-cavitation pump or will the standard high volume pump suffice? Looking for experienced opinions...Thanks
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-10-2021, 04:49 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Melling Oil Pump 10778C Pros & Cons...
These anti cavitation pumps result in a lower pressure at idle than a standard hi volume pump....due to the cavitation slots machined in the cover and housing...
So the question is....Is this a dedicated race engine that spends little time at idle? The 10778C will work ok
or
Is this engine destined for predominantly street use with occasional race use?
Suggest 10778....
Either is a nice improvement over the standard pump....
Make sure you dismantle the pump and smooth over any left over sharp edges on the gears...some of these pumps are really noisy if not cleaned up.
Make sure you use a pickup screen retainer....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-11-2021, 04:24 AM   #3
Ironangel
Ironangel's Avatar
No the truck wont see any street use as the 110 octane race gas is $8.00 a gallon Thanks for the reply.
"Two Seventy Two's"
02 3/4 ton Express
