01-18-2020, 11:32 AM | #11 |
Old member
Re: Starting Engine On Frame?
Make sure you jack the rear wheels up in case. I just went through this with the 68. If it's not hooked up to the rear end it want matter. I had the drive shaft in. I hooked it all up just like it should be.
Last night. https://www.youtube.com/watch?v=TviYONUW5Ag
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
