Which valve covers are better for a 402BB polished alum. or chrome? Thanks
aluminum generally gives a more even seal than chrome plated steel covers, which tend to dimple at the bolt holes... aluminum is more rigid and the force is more evenly distributed.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project Last edited by bigvinnie; 04-15-2004 at 02:08 AM. |
It would be great to have some pics of Alum. and chrome valve covers for 402 BB.Thank you.
Careful, they attack...
Aluminum would be better since they won't bend if you over torque them, but chrome makes the engine more powerful!!
![]() Chrome is good for about 20-40 HP just ask any of the ricers, they'll tell you. |
![]() Join Date: Feb 2001
I bought aluminum for mine but wish I would have went with the chromed aluminum. (small block). Think they would have been a lot easier to keep clean and nice.
Post Whore
![]() Join Date: Feb 2000
Here's a pic of my aluminum valve covers on my bb.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Here are the ones that I have and I like the aluminum for the sealing benefits discussed earlier....
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
The Sauz
I've got chrome, and I'm thinking i might just go back to the stockers, I polished up my new aluminum intake and they leak onto it every few weeks if i don't keep my eyes on em and tighten them up every so often, chrome is just a P.I.T.A in my opinion
68 lwb 2wd (spread between 3 garages) 72 Burb - Flat Deck 92 Yukon 3" lift - 33's - the new bush pig 01 Sierra - Daily Driver (for now) |
I prefer aluminum over chrome as you can always bring it back to a nice finish. With chrome once it peels or gets scratched you must replate it to restore it, later Doug
Aluminum seals better lasts longer.
72 CHEYENNE 10 SUPER 468/400/3.73 |
![]() Join Date: Apr 2004
Take a dremel tool and rough up the inside of the chrome covers where the gasket sets before installing and most of leaks will end!
Fabricate till you "puke"
Aluminum, hands down.....not only do they seal better, but they get rid of heat better ! chrome holds the heat in, & will freakin fry the chit out of your knuckles when hot(big cuss words). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#13 |
"Trucks with Class"
![]() Join Date: Jul 2000
I like the GM late model covers. They are alum with o-rings instead of gaskets...seal real nice with no goo or glue.
#14 |
Half a bubble off!
I have the ones in Pickmup's pic (in fact I got them from him), and am very happy with them. No more leaks, and they look good too! That O-ring seal is a great improvement IMO.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
#15 |
Do the holes line up on those? Do you just not use some of them? I'm Confused???
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#16 |
Half a bubble off!
They were a direct bolt-on for me, just clean the surface area of the top of the heads really well to insure a good seal. I used studs and nuts instead of bolts to secure them, that allowed me to loc-tite the studs to the heads in order to keep them where they belong. They have made a believer out of me, I'll never use steel valve covers again given the choice.
