Old 04-26-2004, 08:04 PM   #1
zzChevy
BANNED
Starter torque spec?
What should the starter be torqued at? SBC 350 Stock starter. Thanks
Chris
zzChevy is offline   Reply With Quote
Old 04-27-2004, 08:16 AM   #2
Nvbowtie
Nvbowtie's Avatar
35 on the starter
11 on the starter brace (full list below)
Component Torque (ft/lbs)
Bell Housing to Block 35
Carburetor to Intake Manifold 13
Choke Assy to Intake Manifold 8
Connecting Rods 35
Cylinder Heads 75
Distributor Hold Down 13
Exhaust Manifold to Cylinder Head 18
Fan Pulley to Harmonic Balancer 23
Fan Pulley to Water Pump 20
Flywheel Dust Cover 4
Flywheel/ Flexplate to Crankshaft 60
Fuel Pump to Timing Cover 20
Harmonic Balancer 120
Intake Manifold to Cylinder Head 55
Main Caps 95
Motor Mount to Block 63
Oil Drain Plug 30
Oil Filter 13
Oil Gallery Plugs 25
Oil Pan to Block 14
Oil Pick-Up Tube to block 8
Oil Pressure Regulator Retaining Nut 35
Oil Pressure Sending Unit to block 23
Oil Pump Cover to Timing Cover 10
Rocker Shaft to Cylinder Head 25
Spark Plugs 15
Starter to Block 35
Starter Brace to Block 11
Starter Brace to Starter 11
Thermostat Housing to Intake Manifold 20
Timing Chain Cover to block 29
Timing Chain Sprocket to Camshaft 48
Valve Cover Hold downs 4
Water Pump to Timing Cover 7
Windage Tray 11
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 04-27-2004, 08:05 PM   #3
zzChevy
BANNED
