Old 05-07-2004, 10:06 PM   #1
402Bowtie
402Bowtie's Avatar
Bed Disassembly question
I have my '72 bed off the frame and am now trying to completely disassemble it. I have every single bolt off and now am stuck trying to cut through the spot welds at the rear of the bed. I have a grinder but can't get the right angle with it. I also have tried a hacksaw and drill but they take tooooo long. I have thought about using a cutting torch, but I am afraid of over doing it. Any suggestions would be greatly appreciated....Thanks...John
402Bowtie is online now   Reply With Quote
Old 05-07-2004, 10:10 PM   #2
bisquik65
bisquik65's Avatar
Do you have an air compressor ? i used an air chisel to get mine off.
bisquik65 is offline   Reply With Quote
Old 05-07-2004, 10:51 PM   #3
walker
walker's Avatar
I used a die grinder with mine, then finished it off with a hack saw. Don't forget the bolts right under where the welds are.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 05-07-2004, 10:56 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Die grinder work's great so will a hand drill with a cut off wheel attached to it...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
