Old 05-18-2004, 08:55 PM   #1
TIMSPEED
TIMSPEED's Avatar
4wd Blazer Exhaust Question: How's yours done?
How would I run a dual exhaust on an 76 K Blazer? Wouldn't the TCase be in the way? Pix would be nice. Thanks
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-18-2004, 09:48 PM   #2
Fry
Mine goes above the TC crossmember on the sides of the transfer case. I can't quite remember exactly since I haven't seen her in the last couple of months.
Fry is offline   Reply With Quote
Old 05-18-2004, 10:20 PM   #3
cochino12
It followed me home?
cochino12's Avatar
Just use some drive shafts instead of ACTUAL exhaust tubing like the PO did on mine
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-19-2004, 08:35 AM   #4
Jonboy
Slots go on anything!
At least it will take longer to rust through, right?
1974 Jimmy- 5.3/4L80e/NP241
Old 05-19-2004, 09:05 AM   #5
Grim Reaper
Need to run short headers or stock mainfolds if it's stock hight or flexy. THe collector flang on a set of long headers will usually hit either the front drive shaft or the sping shackle. You can sneak a 2.5 past the transfer case on a 203 as long as it doesn't have the torque arm on the frame.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
