05-29-2004, 11:47 PM | #1 |
Parting out a 69 3/4 GMC Long and Wide
Bought a donor truck. It will donate to my 68 C10 the 350 Engine, rad, steering column, TH350, cross member, drive shaft, sway bar, and a few other things I'm sure.
Basically the rest of it is up for grabs. Body is pretty though including the bed...no tailgate. It is located in Neenah WI. Let me know if there is anything I can help with. |
05-30-2004, 02:10 AM | #2 |
Donor Truck
Hello Rakort,
By chance does it have any 3/4 ton GMC hubcaps with the black star in the middle? Looking for Stainless or regular steel painted ones. Thanks, Longhorn70gmc
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
05-30-2004, 08:53 AM | #3 |
What kind of condition are the doors in?
05-30-2004, 09:56 AM | #4 |
Sorry guys, no hub caps and the doors are pretty much junk. BTW this is a Camper Special Truck what ever that means. The Hood is the only panel worth re-using.
05-30-2004, 04:02 PM | #5 |
Running on empty
Rakort,
Any mirrors left? I am looking for the medium size camper mirrors; they would be smaller than these ugly things.........
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver |
05-30-2004, 04:21 PM | #6 |
Hubcaps!
Rakort,
Bummer on the caps, but thanks anyway. Longhorn70gmc
05-31-2004, 11:50 AM | #7 |
No Mirrors
No Hub Caps Doors might be better than I thought....I'll look again Keep trying guys we will find something!! Rakort |
05-31-2004, 12:42 PM | #8 |
Im looking for the wire that conects to the water temp sending unit. The end that clips to the sender and some wire.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
06-02-2004, 02:45 AM | #9 |
hows the front clip?
06-02-2004, 07:39 AM | #10 |
Bumper is decent except a twist, hood is good, fenders are ? and at least one has been changed already. The grill is straight, but has some surface rust on the bottom. I'd rate it fair overall.
06-02-2004, 09:13 AM | #11 |
if it was a camper truck it probably has desirable rear gears......you should check that..
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
06-02-2004, 10:18 PM | #12 |
I believe it was a camper special. What are the desirable gears / rearends? A particular ratio?
Thanks Rakort |
06-04-2004, 05:14 PM | #13 |
Brown seat belts?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
