Old 06-25-2004, 10:21 AM   #1
53burb
53burb's Avatar
rear end
I have a "69 Burb 3/4 Ton 2wd. It has a 10-bolt cover rearend, but it is not a GM 10 Bolt. It is also a Full-Floating Rear. Is this an Eaton Rearend??Does anybody know what gears this has w/o counting the revolutions???
Thanks,
Chris
53burb is offline   Reply With Quote
Old 06-26-2004, 01:13 AM   #2
Livrat
Member #1049
Livrat's Avatar
Hi Chris...
It does sound like the Eaton...
Normally... if your truck is a V8 Auto.. the ratio is most likely 4:10.... A few of the 69 Big Block trucks had a 3:54..
The only way to know for sure what your ratio is....is to clean off the pumkin and look for the "Axle code" which will be stamped into the housing
Livrat is offline   Reply With Quote
Old 06-28-2004, 09:55 AM   #3
53burb
53burb's Avatar
Thanks,
Do you happen to know where the stamping is located at??
Chris
Old 06-30-2004, 05:24 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
Might be a Dana 60.
Old 07-07-2004, 05:44 PM   #5
fede
Thumbs up
Originally Posted by '68OrangeSunshine
Might be a Dana 60.
I also have a '69 3/4 2WD and mine has a Dana 60.
fede is offline   Reply With Quote
Old 07-08-2004, 09:04 AM   #6
53burb
53burb's Avatar
Don't Dana 60s have a shape to them other than round like mine does???
Old 07-08-2004, 09:29 AM   #7
fede
This is what mine looks like, at least the bottom half of it.
I am no expert, but when I bought my burb, the PO told me that it was a Dana 60.
Old 07-08-2004, 11:16 AM   #8
53burb
53burb's Avatar
I believe that that one is a Dana 60. Mine doesn't look like that. Mine is more of a round shape...Thanks for the time tho...
Old 07-09-2004, 09:52 PM   #9
monks21
What you have is an Eaton rear end. These were fairly common on Chevrolets throughout the sixties up until 70-72, I can't remember.They were replaced with a corporate 14 bolt in the early seventies. The Eaton has a round cover on the back and the pig will unbolt out of the front of the housing. It is also common for them to have locking differentials from the factory, if that sort of thing rows your boat. The three I own have 4.11 and 4.56 gears. Does anyone know if 3.73's were available? John
monks21 is offline   Reply With Quote
Old 07-10-2004, 12:33 AM   #10
1969 GMC
1969 GMC's Avatar
The eatons appeared in 3/4 and 1 ton trucks from '47-'72.
4.11, 4.57, and 5.14 gears were available from the factory, and there may have been a 3.73 set manufactured aftermarket, but is no longer available. There was a 3.90 set available aftermarket until recently. If your burb had a 350 originally, then it will probably have 4.11s. If it had the 250, 292, or 307, then it most likely has 4.57. If it had the 396, then the rearend should be a dana 60 with 3.54 gears, but may be a 4.11 eaton. And as previously mentioned, it may have a factory No-Spin (Detroit Locker).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-12-2004, 09:22 AM   #11
53burb
53burb's Avatar
Thanks for the help guys...What is the easist way to check if it had a 307 in it? It currently has a 350. I am sure it came with a SBC originally. The 350 is not the original engine.
Old 07-12-2004, 03:05 PM   #12
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Check your glove box option sticker, or run the VIN number through here:
http://www.americanclassic.com/paint_test.asp
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-15-2004, 09:24 AM   #13
53burb
53burb's Avatar
The VIN only states that it came witha V8, not what size. The glove box sticker does not state anything about the rearend or RPO code H052 or H072...but it is definately an Eaton Rearend, just don't know what gears it has...
