Old 07-05-2004, 11:04 AM   #1
Red69stepside
Red69stepside's Avatar
69-70 grille insert/ Picture
I just saw the grille shell and insert in Tim Christian's catalog. Does anyone have a pic of how this insert looks installed? Te catalog says it's molded plastic, does that mean it's paintable?
Red69stepside is offline   Reply With Quote
Old 07-06-2004, 03:05 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
I would assume it looks like any other grill installed. If you want to paint plastic, you need to use one of the spray paints made for plastic, Krylon calls theirs fusion. It actually melts the surface just enough for the paint to stick.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-06-2004, 03:41 AM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Is this what you're looking for? This is an old shot of my truck before I started body work. I have my inner grill painted with a couple of coats of dupont gloss black with a couple of coats of clear ontop of it. My headlight bezels are the same way. Hope this helps.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 07-07-2004, 04:48 AM   #4
Red69stepside
Fred & HotRod70C10:
you da man. x2. this is just the info I was looking for. Yer pic and info make it all clear.
I like that paint job on the inner part or Hotrod's grill. really sets off the outer grill.
Old 07-07-2004, 09:14 AM   #5
Hotrod70C10
Low & Slow
Hey, No problem. By the way, I did prime and sand it before I painted.... I should have mentioned that before. Good luck.
4.5/6 drop
Old 07-07-2004, 10:23 AM   #6
n737nc
Hey Hotrod70C10, Who fell asleep in the passengers seat?
n737nc is offline   Reply With Quote
Old 07-07-2004, 07:29 PM   #7
Hotrod70C10
Low & Slow
Oh.... that's my old lady...... She wouldn't get out of the truck so I had to smudge up her face.
4.5/6 drop
Old 07-08-2004, 04:16 PM   #8
Red69stepside
Appreciate the advice. I'm getting to it as soon as it comes back from the shop with the new disc brakes.
