07-27-2004, 11:35 PM | #1 |
Fuel Tank Behind The Seat
Have ya'll had any problems with alot of built up air inside the fuel tank? Is this something that I need to be concerned about or just normal.
07-28-2004, 02:37 AM | #2 |
I've never experianced any problems, welcome to the board!
07-28-2004, 05:24 AM | #3 |
Welcome, I would change the gas cap It isn't venting.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
07-28-2004, 05:34 AM | #4 |
Except for the "Danger-Is-My-Business" aspect of leaning back against 22 gallons of highly flammable-explosive fluid, it's really a good set-up. The fuel pours into the tank fast with no problems. No air build up. You should have self-venting gas cap. It wasn't until '71-'72 that GM went with a gastank vent that vented out the door pillar for emission reasons. I had a Sub and have a K/5 and I always have to burp the flat tanks to get them to take enough gas. Fuel feed is sometimes a problem when the tank is in the rear, I have found. Never a problem from cab-mounted tank. You do want to avoid roll-overs or long skids down the freeway on the left side, but I fail to see the attraction of putting a tank where my spare is. Where would I put that? Never a problem on a show truck, but some of us work for a living and a working truck is part of that life.
By the way -- welcome aboard.
07-28-2004, 10:27 PM | #5 |
Old Skool Club
I replaced my original chrome gas cap with a locking cap from NAPA. Removing either one always caused a whoosh when it loosened. I guess it was just making room for the sucking sound that followed when I put gas in it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
07-28-2004, 11:20 PM | #6 | |
20' Daredevil (Ret)
I also have a NAPA locking cap, but it seems to be well vented. No whoosh.....
07-29-2004, 07:43 AM | #7 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
