Old 08-02-2004, 09:15 PM   #1
NorthWolf33
Universal Joints
Hey could use some ideas here. My driveshaft was missing a piece out of the circle thing that the universal joints sit in. SO I went and bought a used one and just going to replace the old joints on it. BUt these joints are in there so freakin tight that my vice can't even press them out also they are the type with the plastic filler ring in the center that you cant get to. I ended up just cutting the end universal joint out but the caps are still in the holes so does anyone have any idea how to get these caps out of the holes? Cause its tempting to beat the liven daylights out of it but Im sure Id prlly just end breakin it. SO any ideas or suggestions would be great otherwise Im gonna have to take it somewhere.
NorthWolf33 is offline   Reply With Quote
Old 08-02-2004, 09:57 PM   #2
1972C10
1972C10's Avatar
Heat the driveshaft with a torch around the u joints it will melt that plastic crap out then install your new inside keeper u joints.
1972C10 is offline   Reply With Quote
Old 08-03-2004, 01:08 AM   #3
NorthWolf33
thanx for the idea Ill give it a whirl tomorrow.
Old 08-04-2004, 11:18 PM   #4
a28doc
'87 V20 4x4
a28doc's Avatar
use a ball peen hammer and a socket just slightly smaller than the cap is support the shaft end on something like a piece of wood only leaving open the cap openings hope this helps Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 08-05-2004, 02:21 AM   #5
NorthWolf33
hey thanx for the ideas they finally came out.....when ya heat them with a propane torch theyeventually get hot enough to where the plastic crap literally pops out of there and then it can be beat out with a socket and hammer.
