08-13-2004, 01:12 PM | #1 |
C10 Club Tennessee
Do I need a adj panhard bar?
I'm installing 4 inch drop rear coils in my 70. I'm definitely going to put a shock relocator kit on it, but do I need the adjustable panhard bar?
Thanks,
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
08-13-2004, 01:22 PM | #2 |
67 is sold
Yes. It is recommended by ECE to use it with a 4" or greater rear drop.
08-13-2004, 01:36 PM | #3 |
yes sir, from what I have heard, anything over a 3" drop requires and adjustable bar
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
08-13-2004, 02:54 PM | #4 |
Senior Moment
Put your springs in without it and measure for center on the rear-end.
You'll want it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
08-13-2004, 02:57 PM | #5 |
I have 4" drop springs too. What about getting some good measurements and shortening a stock panhard bar?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
08-13-2004, 03:35 PM | #6 |
Keepin an eye out
Ive got at least a 4" drop in the rear and I still have the stock bar. It looks centered. I do have a ECE one but it wont clear the tailpipe on the driver side due to the thicker diameter.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
08-13-2004, 03:51 PM | #7 |
Cause the Chicks DIG IT!!
could this be why when i dropped my truck 3 up front and 5 in the rear i have a tilt to the left in the rear? Thing seems to handle fine but i have that damn lean
08-13-2004, 03:57 PM | #8 |
71 DELUX
I have 4.5" of rear drop and have not yet put in an adjustable bar. Eventually I probably will, but it is not "off" enough to cause me any heartache at this point. Truck tracks straight and does not look cockeyed or crooked. Just my .02 worth.
Shortening a stock bar? Probably not worth the effort, since you'd want to get it so "right" and then you could eventually change your ride height and then it would be wrong again. I thought the rule of thumb was that you don't want the bar to run "upward" at all. No? If it is, then you can be sure that your rear-end (your truck's I mean :p) is not moving up and down correctly.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
08-13-2004, 04:50 PM | #9 |
Old Skool Club
I'm running 4-inches of drop in the rear, with the adjustable track bar. My rear end is centered, and the alignment is spot-on with factory specs (2.5 inch drop in front). I also have the rear shock relocator mounts and shorter shocks.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-13-2004, 05:30 PM | #10 |
C10 Club Tennessee
It sounds like I need to install the springs and then see if my panhard bar is going upwards. If I needed to buy one where's the best place?
thanks
08-13-2004, 09:48 PM | #11 |
I have seen it both way we put a 5in drop under my sons trck and under a burb we are working on and did not need one then I have seen a 4in drop that does need one. We do keep them in stock. Tim
