08-16-2004, 05:20 PM | #1 |
Built 10 bolt and 12 bolt locked 4.10's Atlanta
These have been gone through in the last couple years. and no leaks ready to run.
Front is 10 bolt out of a 79. 4.10 gears EZ locker, Mile Marker hubs that are nearly new are negotiable. Rear is a 12 bolt out of a 79. 4.10 gears Detroit full case C locker, Disc brakes. $800 firm for the pair. The Detroit is $500 bills new, the EZ is $300 new. If you went to 4Wheel parts and paid to buy this exact set up on your own axles, installed you would leave $2,000 lighter...feel free to check it out. I will take a set of stock matched 3.08 axles in exchange for partial payment for the next couple weeks. Basicly you drive up your truck we swap axles and you ride home on built axles. You will have to modify your CV and get a adj PV to run the rear discs. This is a checking interst post till the truck sells or I have a chance to go get a set of replacment axles and I have a line on them so if you want to use your axles as partial payment now is the time. Local pick up only at this time.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-23-2004, 12:21 PM | #2 |
Top
