09-09-2004, 09:24 AM | #1 |
71 Chevy 4x4
Don't make me pull my gun out........
...........and rob these things from your truck ! Took the rear axles out of the old rearend (talking about my truck here ) yesterday and found out that i need the emergency brake lever that hooks to the brake pad .So not only am i needing those parts i'm still needing the rear cables and the rear cable slack holders for a 71-72, 3/4 ton , 4x4 with a four speed tranny if that makes a differance . Someone told me that it made a differance , i'm not sure ?!?! So , any you guys have these things , please help a brother out here ! *on my knees here , begging* I pay cash too !!!
I might be interested in a good or new 4 barrel carb ,for a 454bb, if you have one ?!?! Also in need of a flywheel dustcover for a bigblock engine with a four speed tranny. Thanks
Tenn.man(a.k.a.Danny Cummings) Last edited by Tennman; 09-09-2004 at 12:28 PM. |
09-09-2004, 11:12 AM | #2 |
I might be able to help you out don't know but maybe on the brake lever . Do you if the 1/2 ton lever will work on the 3/4 ton ? if so i got one and its yours for the ride . Jose
09-09-2004, 11:20 AM | #3 |
71 Chevy 4x4
Not forsure if the 1/2 and the 3/4 ton brake levers are the same or not ?!?! Problably not,if i was a betting man ! Thanks Jose just the same.
Tenn.man(a.k.a.Danny Cummings) |
09-09-2004, 12:20 PM | #4 |
Young Gun wth Fast Inline
Sent you a message on the carb... .i also have several quads that ran, but need seals and what not if you want one of them.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
09-09-2004, 03:17 PM | #5 |
computer illiterate
thought you where going sbc this time? i have a 454 with a quadrajet on it i dont think im gonna use.
72 2wd blazer 72 swb 4x4 |
09-09-2004, 04:25 PM | #6 |
71 Chevy 4x4
Sent you a PM meat ! Thanks !
09-09-2004, 06:55 PM | #7 |
user # 2756
Danny, Which rear end do you have? Sounds like the eaton if you had to remove the axles to look at the brakes. I seen somebody parting a 67 3/4 ton w/ eaton rear that might still have those parts:
http://67-72chevytrucks.com/vboard/s....php3?t=118522
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
09-10-2004, 06:50 AM | #8 |
How wide are your brake drums/shoes? I might have what you need.
09-10-2004, 09:19 AM | #9 |
71 Chevy 4x4
Thanks Jim for the link,and Meat and Dean i sent ya'll a pm ! Call me at 931-473-5401 if ya'll like .
