Old 09-21-2004, 01:55 AM   #1
billsbowtie
billsbowtie's Avatar
does it hurt a eng. to run with only headers
like moving it around the yard and short trips with nothing but headers on it thanks
billsbowtie is offline   Reply With Quote
Old 09-21-2004, 02:08 AM   #2
LooseCannon
no, not a bit...
Think about all the cars at the drag races
LooseCannon is offline   Reply With Quote
Old 09-21-2004, 02:12 AM   #3
RON WOODGEARD
Resident Young Old Dude !
Only if you have close, Unfriendly Neighbors.....
RON WOODGEARD is offline   Reply With Quote
Old 09-21-2004, 02:21 AM   #4
kingsolver72
10/30/19
kingsolver72's Avatar
I definitely would not go very far with open headers.Might be a little hard on the valves.
kingsolver72 is offline   Reply With Quote
Old 09-21-2004, 02:23 AM   #5
Russell
Professional Grade
Russell's Avatar
Don't run it long enough for the heads to get real hot because you can warp the valves when cold air come rushing up the headers after you turn the truck off. Basically causes the valves to shrink faster than the rest of the heads, warping them.
Oh, the neighbours can be a pretty big factor too Mine sued us over excessive barking of our rather quiet dog, and quickly quit after I agreed that if they stopped calling, I'd stop working on my motor late at night
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-21-2004, 02:23 AM   #6
bigjimzlll
bigjimzlll's Avatar
I think thats an old wives tail....no headers at all would cause some valve problems, but headers scavange the exhaust..mufflers do nothing but quiet and restrict flow.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-21-2004, 02:45 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I know this is apples to oranges, but I drove an 81 Citation for about 9 or 10 months in high school, and all it had on it was an exhaust manifold. No pipe, no converter...nothing.
I drove that sucker for 5 or 6 hrs a day running to cincinati every day to see my old girlfriend.
Not a single problem. I say it is BS.
Old 09-21-2004, 02:49 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
the only thing it does is lean out the cylinders to to basically no backpressure. short trips around the yard etc. will be fun, I mean fine.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-21-2004, 02:52 AM   #9
billsbowtie
thanks guys
Old 09-21-2004, 02:55 AM   #10
kingsolver72
10/30/19
Wives tale or no wives tale why run open headers for long distances?..."BS" whats Barbara Striesand got to do with anything?
Old 09-21-2004, 03:20 AM   #11
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
people run those cherry bomb glass packs that bolt right to the header, they are straight through and only 18 inchs long or so, dont see how that would make that big of a difference
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-21-2004, 03:58 AM   #12
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Open headers won't hurt it,I prefer it,but the law doesn't support my views
I just have manifolds,and the mufflers stop right under the cab.I ran the 71 that way for 2 years,and I plan on running this truck that way for a while.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 09-21-2004, 06:32 AM   #13
724wdcopper
graphic designer
724wdcopper's Avatar
why is it Harleys get away with thunderously loud exhaust, but if you are taking your rig to the muffler shop, you are sure to upset the neighbors and attract cops like barbeque attracts wasps?
is there some rule i dont know about that makes motorcycles exempt from noise ordinances?
724wdcopper is offline   Reply With Quote
Old 09-21-2004, 06:38 AM   #14
Russell
Professional Grade
Russell's Avatar
I've often wondered the same thing...
Old 09-21-2004, 10:46 AM   #15
Longhorn Man
it pisses me off that the HD bikes can have blue dots in the tail lights too.
Old 09-21-2004, 11:23 AM   #16
GMC AMI
GMC AMI's Avatar
Headers wide open.
It will not harm the engine, what do you think about all the drag racers running open headers? We always uncapped the headers at the drags and ran the cars hard and fast with no problems other than with your hearing!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 09-21-2004, 05:24 PM   #17
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
In my expereinces, running open headers is alright, but its always a safe bet to plug the collectors immeadiatly after you shut off the engine. Just a preventative thing...bettert to be safe than sorry IMO.
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 09-21-2004, 05:45 PM   #18
nate68
good idea, i wouldn't want any "creatures" getting stuck in the headers
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-21-2004, 09:23 PM   #19
Longhorn Man
They'll blow out as soon as you fire it up...don't worry about them.
Old 09-21-2004, 09:27 PM   #20
cochino12
It followed me home?
cochino12's Avatar
I was wondering the same thing, I'm putting new headers on soon and the exhaust shop is about 20 min. away.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-21-2004, 10:07 PM   #21
gr8scott51
gr8scott51's Avatar
You can't run blue dots????
As for the HD exhaust, a friend got a noise ticket on his Harley and I thought it was quieter than most.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 09-21-2004, 10:12 PM   #22
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
THEMS CALLED "PURPLE HORNIES"
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-21-2004, 10:31 PM   #23
cableguy0
running no exhaust at all ie no headers or manifolds will hurt the motor but running just headers wont hurt a damn things except your hearing
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-21-2004, 10:52 PM   #24
kingsolver72
10/30/19
I don't understand the anger with Harleys.Maybe the Harley rider has a stigma on him that people are not as likely to approach him.So the next time you get pissed off at a harley and or the rider just go and let him know how you feel.I have a 68 c10 that is louder than my 99 custom.Either one will set off car alarms.Gotta like that.
Old 09-22-2004, 12:43 AM   #25
pissonNOS
senior member
pissonNOS's Avatar
haha thats what all the oldies around here call em they just looked at me when i went to the parts store and asked for some purple hornies
69 GMC bagged
pissonNOS is offline   Reply With Quote
