Old 09-24-2004, 01:19 AM   #1
70c10
67-72 Addict!
70c10's Avatar
How do you install sport mirrors?
Last week I mainly posted a question about the steel mounting plate location. Now I know the plate goes "behind" the door skin. Is the plate bolted to the door first, then the mirror and gasket screwed on?. If this is correct how the heck do you get your arm up in there with a wrench to attach the plate?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-24-2004, 01:59 AM   #2
jamesi20
jamesi20's Avatar
sport mirrors
I'm not sure how to do it as an add on but I am not near my truck now,but believe that the tapping plate is welded in the door from the factory.
jamesi20 is offline   Reply With Quote
Old 09-24-2004, 02:26 AM   #3
70c10
67-72 Addict!
70c10's Avatar
I thought the sport mirrors were an option.
Jim
Old 09-24-2004, 02:26 AM   #4
sdkid
I had the arm style mirror, and on that pickup the plate was put up in through the door panel and the nuts were welded to the plate. The plate was not welded to the door. I think the sport mirrors use the same principle to attach.
sdkid is offline   Reply With Quote
Old 09-24-2004, 02:59 AM   #5
pickupman
pickupman's Avatar
Jim, it usually takes 2 people and a skinny long arm. Just have to have someone hold the plate up there while the other puts mirror and gasket on. They were not welded or screwed in place. alot of the time the older one was rusted in place.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 09-24-2004, 03:53 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Thanks Bill. That kind of makes sense since I didn't get any bolts with the mirrors. I just got 3 screws per mirror but they seemed too fat for the plate. I'll be doing this Sunday.
Jim
Old 09-24-2004, 04:07 AM   #7
pickupman
pickupman's Avatar
Jim, 1 other point not sure if you knew or not. there is 1" diffference in mounting point of mirrors. The RH one sets 1" farther to the rear of truck. that is the way they were from factory.
Old 09-24-2004, 04:39 AM   #8
obsesive23
Who me?
obsesive23's Avatar
Thanks for the info I did not know that!
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline   Reply With Quote
Old 09-24-2004, 04:44 AM   #9
sdkid
What is the reason for that?
Old 09-24-2004, 04:46 AM   #10
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
objects in mirror may be closer than they appear. or is it 'objects in mirror are losing' forget which one :p
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-24-2004, 12:31 PM   #11
70c10
67-72 Addict!
70c10's Avatar
Thanks for that tip Bill. As long as I'm close I'll be happy.
Jim
Old 09-24-2004, 02:23 PM   #12
Gee_Emm
I just got some backing plates off of a truck last week. Took the screws out that hold the arm on and the plates just fell.
I took measurements of the postition of them too.
Drivers side is 6 3/4" from the door edge to the mirror arm and the passenger side is 8 1/4"
Vertically the top of the mirror arm sits flush with the body line.
Gee_Emm is offline   Reply With Quote
Old 09-24-2004, 03:26 PM   #13
70c10
67-72 Addict!
70c10's Avatar
Gee Emm, thanks alot for that info!. This should help alot of people asking about or needing correct measurements.
Jim
Old 09-24-2004, 03:44 PM   #14
sactoC10
71 DELUX
sactoC10's Avatar
I got sort of lucky when I put mine on, the factory holes were already there, I simply had to tap the body putty out of them. Also, when in the door, I removed some leaves and other crud that had fallen in there and found an original backing plate... too funny.
Think I did borrow the wife or child to hold turn the screwdriver to get the plate in place, while I held it through the door.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 09-25-2004, 10:51 PM   #15
RShaips
I just put new ones on my 67 SWB. I did not know that they were mounted in different spots. Mine are both 6 3/4 back from the door edge I lined them up inline with the vent window edge. I can see out of the passenger side good enough, I thought that they looked kinda far back the way they are, Not sure I would want to mount them any farther back. They are pretty easy to put on , it helps to have someone inside helping.
RShaips is offline   Reply With Quote
