Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 09-26-2004, 10:20 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Standard and optional equipment listing....1967
This is taken directly from the Restoration catalog for 67. The restoration catalog includes the option book and information that the dealer would have had for you to look at if you were buying back in 1967.
-----------------------STANDARD EQUIPMENT---------------------------
Air Cleaner oiled paper element
Axle, Rear
....C/10 Hypoid semi floating type, ratio 3.73; Capacity 3500 lb.
Battery 12 volt, 54 plate; Capacity 53 Amp-hr
Bodies See Cabs, Bodies & Colors
Brakes hydraulic; Self adjusting; Daul System
Sizes; front 11' x 2'; rear 11' x 2'
Effective Area; drum 276 sq in; lining 167 sq in
Brake, Parking Cable to rear wheels; area 83 sq in.
Bumper Front only, painted.
Carburetor
CS10; single barrel down draft.
CE10; two barrel downdraft.
Clutch
CS10: diameter 10"; area 100 sq in.
CE10: diameter 11"; area 124 sq in.
Cooling
CS10: 1 1/4" radiator core, cross flow type;446-sq in area; 13 lb pressure cap.
CE10; 1 1/4" radiator core, cross flow type;480-sq in area; 13 lb pressure cap.
Controls and instruments; 03, 04, 12, 34 models-
Hand choke; light switch; headlight beam control;speedometer;odometer;fuel guage; Lights for generator, oil pressure,engine temperature, brake warning, directional signals and high beam indicator.
02 models- hand choke; light switch; headlight beam control;speedometer;odometer;fuel guage; generator, oil pressure,engine temperature guages; brake warning light (turn signals and high beam indicators included, but not listed)
Directional Signals; Class A; 2 front and 2 rear; 2 front and switch only on 02 model. Includes freeway lane-change position onswitch & integral hazzaerd warning switch
Engine
CS10; 250 Six; positive crankcase ventilation
Gross horse power..........155 @ 4200 RPM
Net horse power................125 @ 3800 RPM
Gross torque, lb-ft.............235 @ 1600 RPM
Net torque, lb-ft................220 @ 1600 RPM
CE10; 283 V8; positive Crankcase Ventilation
Gross Horsepower..........157 @ 4600 RPM
Net Horse Power...............145 @ 4400 RPM
Gross Torque, lb-ft............275 @ 2400 RPM
Net Torque lb-ft................240 @ 2400 RPM
Exhaust system; Single pipe & alluminized muffler
Filter, Fuel Wire mesh in fuel tank, bronze filter in carburetor
Filter, oil
CS10: full flow; 1 quatr; throwaway type
CE10; Full flow; 1 quart; replaceable element type
Frame 39,000-lb-test steel; section modulus 2.98
Fuel Pump Single Action
Generator 37 amp Delcotron
GVW Plate 5000 lb
Lights Head, Parking, tail, stop; intrument panel, Dome on cab models only, backup on pickups.
Mirror, Rearview:
03 models; Exterior RH & LH 6 1/4" fixed arm
04 & 34 models; Exterior LH 6 1/4" fixed arm and inside primatic non glare shatterproof
02 & 12 models: none
Seat Full-width (except cowl models)
Seat belts; Drivers & passenger (except cowl models) includes retractors
Shock absorbers Front & rear; piston diameter 1'
Springs, front Coil capacity 1250 lb each
Springs, rear Coil; capacity 1250 lb each
Tank, fuel 04, 34, 03 models,- back of seat in cab, capacity approx 21 gal
02, 12 models-inside of frame at rear; capacity approx 20 gal
Tires Five tubeless 8.15-15/4PR front, single rear and spare
Tools 2500 lb mechanical jack; wheel wrench
Transmission
CS10; 3 speed synchromesh; steering column gearshift; ratios 2.94, 1.68, 1.00, 3.14 (rev)
CE10; 3 speed fully synchronized; steering column gearshift; ratios 2.85, 1.68, 1.00, 2.9_ (rev)
Wheels Five 15" x 5 1/2"; attachment, 6 studs on 5 1/2 inch circle; spare carrier under frame; 4 painted hubcaps
Windshield wipers and washers Electric; 2 speed wipers; not included on 02 models
That took me 45 min to type out...I'll do the optional equipment later this evening, my neck hurts.
Longhorn Man is offline
Old 09-27-2004, 11:33 PM   #2
Longhorn Man
Thumbs up
------------------------------------------OPTIONAL EQUIPMENT---------------------------------------------
K46 Air Cleaner Oil bath; capacity, 1 quart
C60 Air Cleaner, Heavy Duty Includes closed positive crankcase ventilationand 1 quart oil-bath pre cleaner; notavailable with 327 engine or on cab chassis models.
C60 Air Conditioning, All Weather includes heater and defroster, HD radiator, battery and front springs& 42 amp generator; not avalible on chassis-cowl models
Axle, Positraction rear; Capacity 3500 lb
G80 Ratio 3.73. Not avalible with overdrive transmission.
G80 Ratio 4.11
H01 Axle, Rear Capacity 3500 lb
Ratio 3.07; not avalible with automatic or overdrive transmission.
H04 Ratio 4.11; included with overdrive transmission.
T60 Battery Heavy Duty; 70 amp-hr; included when hd starter motor or air conditioning is ordered.
E80 Brackets, Mounting For mounting pick up box; chassis cab models only.
J70 Brakes, vacum power
Bumper
V38 painted rear with painted front bumper only (pickups only)
V43 Painted step-type rear (pickups only)
V37 Chrome front (pickups & chassis-cabs)
V37 Chrome rear (pickups only)
P03 Caps hub Chrome
P13 Carrier, Spare Wheel Side mounted; pickup models only
M01 Clutch HD Diameter 11" for 250 engine with 3 speed overdrive or new process 4 speed transmisions only
V05 Coolong, HD Includes HD radiator and extra HD cooling equipment Not avalible with Air Conditioning
Z61 Custom Appearance option: Chassis and cab & pickups only; includes bright metal grille moldings, headlight bezels, vent window frames & windshield moldings, control knob trim, horn button cap; color keyed vinyl coated rubber floor mats; custom emblems. Not available with Custom Sport truck option os ordered.
Z62 Custom Comfort Option: Chassis and cab & pickups only; includes RH & LH arm rests, RH padded sunshade; cigar lighter; special cowl insulation;full depth foam seat with fabric upholstery; under body coating; vinyl door trim. Not available with Custom Sport truck option is ordered.
B98 Custom Side molding: Cab models only; also includes pickup box moldings when ordered on Fleetside pickups only.
Z84 Custom Sport truck; Chassis and cab & pickups only; includes bright metal grille moldings, headlight bezels, vent window frames & windshield moldings, control knob trim, pedal trim, horn button cap, chrome front bumper,special CST emblims, vinyl bucket seats with padded centerconsole; carpeting; RH & LH arm rests; RH padded sunshade;cigar lighter; special cowl insulation; under body coating; vinyl door trim
Engine
L25 292 inline six (CE10 models only); includes 3 speed fully syncronized transmission
Gross Horse Power.............170 @ 4000 RPM
Net Horse Power................153 @ 3600 RPM
Gross Torque Lb-Ft.............275 @ 1600 RPM
Net Torque Lb-ft................255 @ 2400 RPM
Clutch .............................11";124 sq in
Battery.............................61-amp-hr
L30 327 V8 (CE models only) Includes HD front springs not avalible with chevrolet 4 speed or overdrive transmission
Gross Horse Power.............220 @ 4400 RPM
Net horse Power................177 @ 4000 RPM
Gross Torque lb ft..............320 @ 2800 RPM
Net Torque lb ft.................283 @ 2400 RPM
Clutch..............................12" 150 sq in
E81 Floor, pickup box Wood with steel skid strips. Fleetside pickup models only.
K28 Fuel Filter Equipment
Z53 Guages Ammeter, engine temp, oil pressure, not avalible on chassis cowl models, included when tachometer is ordered
Generator
K79 12 - 42 amp Delcron
K76 5 - 61 amp Delcron
K81 23 - 62 amp Delcron
Glass, soft ray
A11 Windshield only not avalible on chassis-cowls
A11 All windows, not avalible on chassis-cowls
K19 GM Air Injection reactor Aproved by the State of California for vehicle registration. Requires Closed Engine Positive Crankcase Ventilation
K37 Governor
250 engine;
1800 - 3000 RPM
2800 - 4000 RPM
292 engine
2200 - 3100 RPM
2800 - 3900 RPM
283 engine (Not avalible with GM Air Injection reactor)
2400 - 3600 RPM
3000 - 3800 RPM
A85 Harness, Shoulder Driver and passenger, not avalible on cowl models or with optional bostrom seats.
C42 Heater & Defroster Delux Air CROSSED OUT...NOW STANDARD
V76 Hooks, Towing Two, front, not avalible with chrome bumper
U01 Lamps, marker Five, not available on cowl models
A97 Lock Side wheel carrier, pickup models only
Mirror, Exterior
D48 front cross view 8" diameter
D32 RH 6 1/4 " fixed arm, pickups only
D32 RH 17 1/4" swinging arm, pickups only
D32 LH 17 1/4" swinging arm, pickups only
D32 RH & LH swinging arm chassis cabs only
West Coast Jr type 6" x 11"
D29 LH only, pickup models only
D32 RH & LH (pickups and chassis cabs)
West Coast Sr type, 7" x 16"
D30 LH only, pickup models only
D30 RH & LH pickups and chassis cab
Z81 Custom Camper Nameplate Chassis cab and pickup only MINIMUM requirements are front stabilizer bar, HD rear shock absorbers, HD rear springs or Aux rear springs, 7.00-15/6PR or 6.50-16/6PR tires
Paint, Exterior See cabs, bodies,& colors section
K26 Pump Fuel & Vacuum Booster; CS10702 model only
V01 Radiator Heavy Duty Included when 327 engine with automatic transmission or A/C or HD coolinf is ordered
U63 Radio Pushbutton control, not avalible on chassis cowl.
Seat for cab models only, not avalible when custom sport option is ordered
A55 Bostrom "Viking" driver seat only
A55 Bostrom "Viking" driver seat plus 2 man companion seat
Z52 Full-depth foam included when Custom Comfort is ordered
A50 Bucket, driver & passenger, includes carpeting and padded center console
Z55K Serial Number Plate (state of Pennsylvania) 2000 pound rear spring required
Shock Absorbers HD
F51 Front and rear
G65 Rear only
U15 Speed Warning Indicator Not avalable on 02 models
G60 Springs, Aux Rear Capacity, 5000 pounds each
F60 Springs, Front Capacity 1350 lb each, included when 327 or A/C is ordered
G50 Springs, Rear Capacity, 2000 lb each
F59 Stabilizer bar, front suspention
K67 Starter Motor, HD Includes HD battery
N40 Steering power Not avalible with A/C or HD cooling when 292 & automatic transmission are ordered
U16 Tachometer Electric includes optional guages, not avalible on chassis cowls
K31 Throttle Control Manual
Transmission
M10 Overdrive, includes 4.11 rear axle ratio, Not available with 327 or govenor equipment
M35 Powerglide, not available with govenor equipment
M49 Turbo Hydra Matic
M17 Chevrolet 3 speed fully synchronized with 250 only.
M20 Chevrolet 4 speed synchromesh, includes 11" clutch, not avalible with 327 engine
M28 New process 435CR 4 speed close ratio
K24 Ventilation, Closed Engine Positive
P01 Wheel covers, full Bright metal, avalible only with 15" wheels
A10 Window, Full-View Rear Chassis-cab & pickup models only
Closed Thread
