10-07-2004, 02:07 PM | #1 |
wtb: front spindles and caliper mount from '73-'74 Blazer
I 'm looking for the front spindles and the backing plate/ caliper mount for a 73-74 blazer. If you have any e-mail me at stevenmc@cox.net
thanks Steve |
10-07-2004, 05:03 PM | #2 |
Are you still 1/2 ton??
either way I have the 1/2 ton stuff for you. I'll figure out a price tonight.. Or i have these for 40.00 plus S&H these are 3/4 ton spindles. I actually got these from a 1/2 ton big bearing hub D44..
Support The Board |
10-10-2004, 11:23 PM | #3 |
I need the 1/2 ton stuff if you have it.
Thanks |
10-28-2004, 10:20 PM | #4 |
I have a bunch of caliper supports, do you need the solid steel ones or the half ones with the lower tin? Where are you located?
10-29-2004, 10:11 AM | #5 |
I would rather the solid steel ones. I need the ones that when measured from the edge of where the spindle is mounted to the bolt hole for the caliper bolt it is a little less than 5". I'm located in New Orleans
Thanks Steve |
10-29-2004, 10:30 PM | #6 |
I have them 70.00 plus the ride in the brown truck
