Old 10-09-2004, 07:42 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Unhappy How do you remove the door latch assembly?
I need to buy and replace a door latch assembly for a passenger door but I don't know how to remove the old one. I removed the 3 screws on the end of the door but don't know how to get the unit past the window channel. Any help would be appreciated. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-09-2004, 09:00 PM   #2
gonebad2
Merciless Butcher
gonebad2's Avatar
Unbolt the weatherstrtip channel ( two 1/4-20 phillips head screws under the door panel and one 7/16" head 1/4 20 bolt on the outside of the door shell. Pull it forward a little bit. It will give you the room you need to get it out. Tip: Re-attach the actuator rods to the new door latch assy BEFORE you bolt it in place. It's a real pain to try and connect them when it's bolted in place.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 10-09-2004, 11:56 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Thanks. I'll give it a shot tomorrow. I remember seeing 2 screws but don't recall seeing the bolt.
Jim
Old 10-10-2004, 08:44 AM   #4
MOTHERTRUCKERS
The bolt is a phillips screw like the others but has a larger flat washer and not the star washer. be careful with the linkage clips they get lost or broken easily.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 10-10-2004, 02:22 PM   #5
gonebad2
Merciless Butcher
gonebad2's Avatar
Mothertruckers is right......The bolt on the outside of the door shell IS a phillips head with a washer attached....Sorry for the bad info.
Old 10-10-2004, 07:43 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Thanks guys. So far I removed the 3 phillips screws. Does the linkage rod just pop up out of the clips?. Ed, I PM'd you about the latch. I hope you got it because I need it ASAP!
Jim
