10-11-2004, 11:21 AM | #1 |
Wanted: a posi unit..
I am looking for a posi unit and some 3.73's for a 12 bolt truck rear end. does anyone know how much it costs to rebuild a posi unit new clutches ect...?
thanks
https://www.ebay.com/itm/295742064443 |
10-11-2004, 11:28 AM | #2 |
67-72 Addict!
My truck already had 3:73's. I bought my Eaton posi from www.tomsdifferentials.com for $280.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-12-2004, 11:51 PM | #3 | |
So you can simply make your current rear end into a posi by buying the posi unit? |
10-13-2004, 10:01 PM | #4 |
yah you could...but if you want 373 or 307 gears the posi carriers are different.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
10-13-2004, 11:16 PM | #5 |
67-72 Addict!
Like Rod said, you have to decide what gears you want/have and then buy a 3 series or 4 series.
10-14-2004, 09:29 AM | #6 | |
buy the whole unit.....I just went through it..new springs ,clutches, spider gears..parts 240 bucks..labor ..230 bucks.....can you say ouch
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
10-14-2004, 10:16 AM | #7 |
Chevy Freak
posi's
I used to rebuild rearends on the side for a few years. Bigjimz is right. It averaged about $200 (it depends on how many of the parts are worn and need replaced......the crosspin was worn about 50% of the time, spider gears would need replaced sometimes, etc.). I would sometimes shim the clutchpacks to get back to the standard thickness, but it was a stop-gap measure. It's almost cheaper nowadays to buy new. Just my opinion.......
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
10-15-2004, 12:02 AM | #8 |
I have a 89k-5 blazer that I just rebuild the rearend. It has Brand new Gm posi unit and 3.73 richmond gears, I have all the reciepts. I want to get rid of the entire truck. I'll sell the entire thing for 1000.00 obo. The tranny is shot and not really sure about the motor. I have more than that in the rearend alone, if you include the install.
