10-18-2004, 04:57 AM | #1 |
Still drivin' a Rat Rod
GMC grilles,what's the difference
Ok I know all the grilles are very similar,but different in many ways.There is the painted one with GMC in the middle,painted without,chrome with and without,also painted in the center,and chrome around the edges.
So which one is which?Is it year specific or option package? Thanks
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
10-18-2004, 05:52 AM | #2 |
its all about the +6 inches
67;
white or chrome, GMC in the center. 68; exact same, without the lettering. 69-70 No more painted grills, same as 68, but with 3 pc 'eyebrow and hood trim" 71-72 similar to the 68 - 70, but with black accents making it look like 2 seperate grills. The pic shows my 69 GMC. hopefully ppl will post there stuff too showing the difference. |
10-18-2004, 07:07 AM | #3 |
Designated A-hole!
MIne's a '70, so it looks just like yours Andy.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-18-2004, 09:04 AM | #4 |
'68s could have the thin chrome leading edge on the grille and fenders, but there is a noticeable difference between it and the chunkier style found on later years. i think its part of an appearance pkg. Also, fenders are interchangeable between all years of GMC (as well as '67-68 Chev). The hoods are the same too...slope hoods in 67-68. '69 and '70 grilles have a thin black stripe around the headlights only, its usually faded off. other than that, Andy hit the nail on the head.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
10-18-2004, 09:25 AM | #5 |
blood type; Retumbo
he is correct for the most part. my 68 is niether white nor chrome. it is painted like an argent silver over bare metal. I know it is OE as I am the second owner. but then again other stuff on my truck doesnt seem to match with the "norm". (i.e. older style armrests, funky rear view mirror etc.) maybe because it was purchased from a farm implement dealer in cattle rancher country.(Ft. Pierre, SD)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
10-18-2004, 09:31 AM | #6 |
My 68 "had" the eyebrows and hood trim, they were so badly beaten up I removed them and temporarily filled the holes. When I get rich I'll replace those pieces.
My grill has the black stripe around the headlights and looks exactly like the one pictured above. This truck is a "Custom Camper" if that has anything to do with it. |
10-18-2004, 09:41 AM | #7 |
If you take a 70 grill and remove the top trim will it work with the 67-68 hood? I have a hood but the top trim is riveted to the grill. I think I can grind the rivets off and keep the mounting brackets but i wonderif it will leave a gap between the bottom edge and the grill (the hood is a chevy hood).
Thanks, Roger
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
10-18-2004, 11:43 AM | #8 |
Happy to be here
Here's a few that I have. I think the top two are 71-72 and the bottom one is 69-70....
10-18-2004, 11:56 AM | #9 | ||
Resident Curmudgeon
Once you have the top bar, hood latch mechanism and hood off a 67/68 GMC, you can use any year grille with these pieces. I plan on doing this with my 72 GMC plow truck someday. I've already amassed the parts. The top bar and hood latch mechanism can be hard to find. Quote:
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
10-18-2004, 12:05 PM | #10 |
here is mine. It's mounted on 67 fenders, There is no trim around the outside of the grille
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
10-18-2004, 12:12 PM | #11 |
here's what my GMC came with....supposedly 72
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
10-18-2004, 02:30 PM | #12 |
I was afraid of that. The 68 chevy grill I've got is looking better all the time...
10-18-2004, 02:52 PM | #13 |
this is a 68.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
10-18-2004, 07:42 PM | #14 |
Thanks,nothing like being in the KNOW when it comes to these things
10-25-2004, 03:14 AM | #15 |
Are there two different bumpers, or should they all have the indentations for the turn signal lights?
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
10-25-2004, 06:59 AM | #16 |
blood type; Retumbo
here is my '68. I wasnt aware of any indents for the lights. I think GMC & Chevy share the same bumper. also my top bar is held to the grill with a plethora of sheet metal screws instead of rivets. (I had to remove it to replace the cam when it still had the I6)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card Last edited by 68C15; 10-25-2004 at 07:01 AM. |
10-25-2004, 08:46 AM | #17 |
Here is my 67 Custom grill.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
10-25-2004, 10:02 AM | #18 |
The indentions are on the top of the bumper,in front of the parklights.Does the chevy bumper have them?
10-25-2004, 10:39 AM | #19 | |
Resident Curmudgeon
67/68 GMC bumpers did not have the indentations. Only 69-72 GMC's did. That means that 67/68 GMC and 67-70 Chevy front bumpers are identical.
