10-27-2004, 12:07 AM | #1 |
Seat question ?
I just installed the floor bracket ( lower portion of passenger tilt latch that bolts to the floor) and am having problems getting the seat to lock into it. The seat stops about 1/2 inch too high for the latch to funtion properly.
My question us, was the floor bracket resting on anything originally that made it sit higher ? I have mine bolted right to the floor. Also, the seat frame has rubber bumpers where it hits the floor that are about 3/8 thick. Are those a correct feature ? Sorry if it is confusing, I just don`t have anything local to look at. Thanks, Bret |
10-27-2004, 08:01 AM | #2 |
You're right the bracket mounts to the floor and there are rubber bumpers on the seat. I can get a pic for you if it helps. Don't know but maybe the latch is threaded so it can be adjusted, I have to check.
69 GMC 1 Ton Longhorn 37 Chevy Coupe |
10-27-2004, 10:14 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
You'll note that on the underside of the bracket that is attached to the rear of the seat are 2 holes.
Those holes are for 1/2" rubber pads to be screwed in place. This will give you the height needed for the latch to catch properly.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
10-27-2004, 11:46 AM | #4 |
Here are a couple of pics. Hope this helps
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
10-27-2004, 12:49 PM | #5 |
YUP...that's how it's supposed to look.
You can get 1/2" rubber at Orchard Supply,at least here in Cali anyway. I'm sure any local hardware store could hook you up though.
10-27-2004, 06:48 PM | #6 |
Thanks !......exactly what I needed.
10-29-2004, 11:10 PM | #7 |
That is just what I have....I think.
My problem is that the "male" portion of the braket does not go deep enough into the lower portion to let the locking pin engage. Here is a pic to show what I have. I removed the lower bracket after I had problems, thinking it needed to be lifted in some way. Possibly the Rhino liner is too thick and threw off the height where the rubber bumpers hit ? Last edited by teamharvey; 10-29-2004 at 11:15 PM. |
10-30-2004, 10:20 AM | #8 |
You could try shimming the female bracket up with some washers.
