Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 11-04-2004, 06:39 PM   #1
Hunter
Lovin' Arizona Since 1961
Hunter's Avatar
Thumbs up HotRod Heaven's ProComp HEI Distributor
Well, I was bored today waiting for some more resto parts from Athey's so I put the ProComp HEI distributor that was sitting in the closet since the end of August. Pulled old spark plugs. Turned the motor over till the rotor on the old distributor was pointing to #1. Put new spark plugs in. Pulled the old distributor. Pulled old coil, clipped and taped old wiring. Dropped in new distributor. Pulled new distributor back out. Turned oil pump shaft with screwdriver. Dropped new Distributor back in. Plugged in wiring. Built custom wire set with Accel's kit from Checker at 26 bucks. Truck fired right up. Moved distributor around a bit till motor ran smooth. Vroom, Vrooom!
Got this from HotRod Heaven for $89 plus shipping. Works great.
Check out: http://www.hotrodheaven.com
Piece of cake. Anybody need a points distributor, complete? Free? Best, Hunter
"Religion is like a toothbrush: Everybody should have one, but I don't want yours" - Will Rogers
Hunter is offline   Reply With Quote
