11-08-2004, 08:42 PM | #1 |
which conversion is better?
I have got two trucks a 72 lwb(parts) and a 68 lwb. I am fixin up the 68. I want to use the disc brake setup and five lug. I have not decided if i want to just put my cab on the 72 frame or just swap out the front end and rear on the 68 for the 72? I also have a a front cross member complete with whole steering and rear to match from a 73 van! I beleive the van's setup is the heavy duty style. I know i have enough to build two frame setups which one is going to be better? the 72 style or the 73? Whatever i have left i will restore to swb and sell!
What kind of gear would have been in that van rear? I know it was an automatic! |
11-10-2004, 11:10 PM | #2 |
58 people looked and no one knows what i am talking about? I am in the right section arent i?
11-11-2004, 06:41 AM | #3 |
Life is a gamble
I was hoping someone else would reply, but I guess not. Here is what I would do:
I would take the cab, fenders, hood, from the 68 and put it on the 72 frame. I honestly don't know squat about the 73 van set up, except that maybe you can use a Tilt column from it, if it had that. I doubt anyone would want to guess at what gears are in the 73 van. Its best to just take off the cover and find out for yourself. Sorry I couldn't be more help
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson Last edited by ACES; 11-11-2004 at 06:43 AM. |
11-11-2004, 07:59 AM | #4 |
Does the van have light duty or HD suspension? Light duty would be the rubber style bushings, HD would be the rubber 'lined' steel inserts similar to 64-72's.
If it has the steel 'lined' bushings there's not much advantage to swapping. I would do whatever takes the least amount of work to accomplish (work smarter not harder). Use the disc set-up from the 72 whichever frame you utilize.
11-11-2004, 04:11 PM | #5 |
I think I'd use the 72 frame with the 68's sheetmetal. I'm in a similar situation...I've got a 69' frame with 72' running gear and I'm going to swap all my sheetmetal over.
Like Aces said, I don't know anything about van's other than the steering column will fit in our trucks.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
11-14-2004, 09:29 AM | #6 |
Thanks for your opinion guys! I was wondering if anyone could understand my message! Well what i will probably do is use the 72 chassis(it has had a total rebuild of suspension parts) I will keep the 73 van parts and put them on my 68 frame when i finish the other truck. And sell it or just buy another cab and build another truck! since i am torn between bagging it or just lowering it?
Oh yeah, the 72 has leafs in the back. Should i transfer the the coil setup from the 68 or just buy a 4 link? |
11-14-2004, 09:58 AM | #7 | |
So.......after all of that and now that you have provided some more info (which is what I was waiting for) Make it simple...Put the entire (rebuilt) 72 front end (crossmenber and all) in the 68 frame and drive it. I would keep the 68 for the coil set-up. There is no point is swaping the entire frame to get the 72's front suspension and then putting the 68's rear under it. |
11-14-2004, 10:14 AM | #8 | |
Didnt you read this after you read my second message? especially the part where i said "I was wondering if anyone could understand my message!" Second i was focusing more on the front end not the rear . the reason i asked in the first placeis i know that balljoints for th 73 are differant (maybe sturdier) and the drop spindles cost less but will bolt up!and i know i have the thicker brakes on the 73 as to the 72. I would like to strip and paint both frames but i want to get the chassis setup i am going to use most of the time setup first! I know it is confusing but bear with me! If i use the 73 i will just put the van setup on my 68 frame and if i use the 72 setup i will put the 68 metal on the 72 frame after i repaint it! you understand? |
11-15-2004, 12:55 AM | #9 |
use the 68 frame put the 72 suspension on it...
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
