Old 11-17-2004, 02:46 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Where can I get this type of connector?
Do they sell the connector for this end of the temp ssending unit at the parts store or do I have to go to the junk yard?. The factory connector is missing from the harness.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-17-2004, 02:55 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Buy an assortment of crimp-on wire connectors and ends. One of the ends in that assortment designed to slide onto spade connectors can be used. You may have to widen the gap on the connector some...or you can go to a JY and splice on the GM unit.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-17-2004, 02:59 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Thanks CPNE, I'll probably go to the junk yard to keep the factory style connector.
Jim
Old 11-17-2004, 03:00 PM   #4
grayw0lf
Mine was missing as well. I do not know where you can find teh connector, but I do kno wa work around that doesn't look too bad. Take a normal female spade type connector & bend it slightly open so it will slide on, & then pinch it shut again. it will hold itself in place just fine.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 11-17-2004, 03:10 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Sounds like an easy "Plan B"
Jim
Old 11-17-2004, 04:39 PM   #6
fatfords
fatfords's Avatar
You can get the metal crimp contact from Mad Electrical http://www.madelectrical.com/catalog/flat-blade.shtml
Part number 56F is what you will need. The plastic part can be made from most any single wire female connector housing by cutting a groove in one side of the plastic so the pin contact can slide into the female contact.
Good Luck!
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 11-17-2004, 05:36 PM   #7
1-PU70
1-PU70's Avatar
Here you go
http://www.ecklers.com/product.asp?p...9FCWUJL3A34VN4
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 11-17-2004, 09:36 PM   #8
OhioDan
OhioDan's Avatar
Is there an auto electrical place in your town? If so, they would have the connector you want also. Won't have to scrounge junk yards that way. Just my $.02 .
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
