Old 11-27-2004, 03:11 PM   #1
cysko9
MI '69
cysko9's Avatar
Controll Arm.... should i replace?
I just pulled these off my frame today and started picking at the rust that crept into it... Its seperated it quite a bit and im wondering if i should replace it... if so, do they make new ones or will i have to salvage a set off soemthing....
heres some pics
1967 Chevy (Project Frankenstein)
1973 K5 Blazer
cysko9 is offline   Reply With Quote
Old 11-27-2004, 03:39 PM   #2
neonlarry
neonlarry's Avatar
Do you really need to ask!!
You can get some new light weight ones here:http://www.stockcarproducts.com/trkarm.htm
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-27-2004, 03:42 PM   #3
cysko9
MI '69
cysko9's Avatar
haha, yah, probably not...
thanks
1973 K5 Blazer
Old 11-27-2004, 04:57 PM   #4
roj2323
19lbs eh they must be aluminum. anyone got pictues of them from up close? do they have a bolt hole for the springs?
ondrew
roj2323 is offline   Reply With Quote
Old 11-27-2004, 06:42 PM   #5
cysko9
MI '69
cysko9's Avatar
yah, kindof what im wondering.... thats a lousy picture they have in there....
1973 K5 Blazer
Old 11-27-2004, 09:57 PM   #6
neonlarry
neonlarry's Avatar
I think these might be the arms HRTH uses in their kits.
http://207.44.196.117/vboard/showthread.php3?t=129097
Old 11-27-2004, 11:19 PM   #7
cysko9
MI '69
cysko9's Avatar
yah, seems like it...
thanks
1973 K5 Blazer
Old 11-29-2004, 09:54 AM   #8
rodnok1
rodnok1's Avatar
several board members have had good used rear trailing arm sets for sale in the past. Yours are pretty bad off and would be hard to fix.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 11-29-2004, 01:13 PM   #9
cysko9
MI '69
cysko9's Avatar
good idea
1973 K5 Blazer
