Old 11-28-2004, 11:34 PM   #1
chevybill
chevybill's Avatar
Question Special tool needed to remove pittman arm and idler arm?
I am about to start my front suspension and steering rebuild.
Do I need a special tool to remove the pitman arm from the steering box? and the idler arm?
Can I hammer and pry (carefully) these two pieces off or must I have some special tools?
What are some suggestions for coil spring compressors? I am working on a rolling chassis with no engine or drive train.
Thanks for your help and replies.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-28-2004, 11:38 PM   #2
TheFabShop
To take the coils out I put the frame on jackstands and take the lower ball joint nut off with a jack under the lca let the pressure off slow.You can rent a pitman arm puller from your local parts store.
TheFabShop is offline   Reply With Quote
Old 11-29-2004, 12:05 AM   #3
cableguy0
yup your going to need a pitman arm puller without it you could beat on it untill your arms falls off and it will be right where it was when you started
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-29-2004, 04:28 PM   #4
chevybill
chevybill's Avatar
will the pittman arm removal tool also install the new pittman arm? or does this call for another tool?
Old 11-29-2004, 06:25 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
To install the Pitman arm, you use your impact to pull it on with the nut.
