Old 12-01-2004, 04:46 PM   #1
BK
BK Built
BK's Avatar
trailing arm perches
I got a front suspension setup and rear axle from an early 80's chevy, and im gonna swap in the front suspension soon. I also would like to do the back at the same time, and i was wondering if i should cut the perches off my original axle(its a 65 panel with trailing arm) or is there somewhere i can buy them. ALso, ill be building blocks for it, and probably weld the perches on a little different from stock to compensate for the added pinion angle. Thanks.
BK is offline   Reply With Quote
Old 12-01-2004, 06:02 PM   #2
neonlarry
neonlarry's Avatar
Try here $49:
http://www.earlyclassic.com/catalog.aspx
type in keyword axle saddles.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-02-2004, 04:20 AM   #3
68LSS1
68LSS1's Avatar
Got mine at Stock Car Products for $39.95
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
