Old 12-12-2004, 02:00 AM   #1
jakeslim
Premium Level Member
jakeslim's Avatar
"lurching" engine! Help
Ok, I drove my 69 to its new home(moving) today and it wanted to stall out
when I gave it gas..it was lurching real bad! It runs perfect in park, i can pump the pedal with no stumbling, vacuum is good, oil pressure good etc.
it was most evident going up hill...geeez..it was lurching so bad it must have looked like i was pumping the gas then hitting the brakes to the passer by's.
Any thoughts? I fuel pump is new, the carb is rebuilt(electric choke) , the distributor. Its a 4speed with new clutch also. I think it may be the distributor but have no idea...????
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 12-12-2004, 02:23 AM   #2
shadetree
shadetree's Avatar
I vote "stuck choke". Other things to check: crossed ignition wires, badly fouled spark plugs, stuck float/bad needle and seat (gasoline gushing into intake manifold). Hove I've been some help.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 12-12-2004, 02:27 AM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Fuel filter or there might be a kink in the gas line somewhere.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
