Old 12-15-2004, 02:56 AM   #1
Kania2k1
Kania2k1's Avatar
Size of rear C-notch
Hey guys, I'v ebeen reading all, or a majority of the air bag posts, and I came up with a question I didn't see really answered. I'm looking to lay the frame on my 70 LWB. I'm going with the 1.25"-1.5" front crossmember drop, but the question I have is regarding the rear. How big of a notch will I need? I have a plan to work the bed wood around the notch and to my best calculations, it should look pretty trick. I'm leaning towards the Suicide Doors 8", but if I need the 10", no biggie. Just want to know before I have to send parts back or worse, "unweld" them. Thanks y'all, great site.
2001 Silverado Z71 Extended Cab Sportside
1970 C10 Fleetside Longbed
Kania2k1 is offline   Reply With Quote
Old 12-15-2004, 03:10 AM   #2
fastbagged68
fastbagged68's Avatar
What size tire you going to run? That makes what size notch will need to be.
fastbagged68 is offline   Reply With Quote
Old 12-15-2004, 05:55 AM   #3
Kania2k1
Kania2k1's Avatar
I going to be running 20" in the front, and 22" in the rear. These are the rims I'm looking at right now: Lusso Truck Porbable 8" wide front, 9.5" or 10" in the rear, wider if I can without any major fender work.
Old 12-15-2004, 03:12 PM   #4
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
With a 10" wide wheel in the back you won't be able to go side to side or the tires will rub. Mine rub with 17"X8.5" with 255 55 17 tires. Need to do a slight tub.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
