Old 12-16-2004, 08:57 PM   #1
tim_and_bobbi_blazer
Which water pump came stock on Blazers?
My 4x4 Blazer has small block 350 and a short neck water pump. When I went to the shop today to get a new water pump, the parts guy says it's suppose to be a long neck pump. That means everything else I have would be wrong as well.
Do any of you have short pumps on your 4x4, small block Blazers?
Thank you
Bobbi
See my Blazer Restro Pictures HERE
tim_and_bobbi_blazer is offline   Reply With Quote
Old 12-16-2004, 09:12 PM   #2
Livrat
Member #1049
Livrat's Avatar
Our trucks up thru 1972 used the short water pump... the parts guy is misinformed... GM Cars went to the long pump in 69....
Livrat is offline   Reply With Quote
Old 12-16-2004, 09:15 PM   #3
NuBomb
NuBomb's Avatar
I got the wrong one from the parts store a while back, but I'm not sure which one mine is. Here is a pic of the one I took off. Is it considered the short or the long?
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 12-16-2004, 09:31 PM   #4
Livrat
Member #1049
Livrat's Avatar
thats the short water pump
Old 12-16-2004, 09:52 PM   #5
NuBomb
NuBomb's Avatar
Thanks. I thought the first one was bigger. I guess their computers are wrong cause they immediately pulled the long pump. Later
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
Old 12-16-2004, 10:12 PM   #6
Thanks for the reply
Thanks Livrat. I figured it must be a short one I needed because everything else was set up for it.
Thank you
Bobbi
