Old 12-19-2004, 01:48 PM   #1
kendog
floor heater not heating
94' 1500 with 181k on it.......Just love it! When I put the floor heat on only half comes out, the other half comes out the defroster. The same happens with the AC on. Half comes out the defrost and the other half comes out the panel and the floor. Any help would be appreciated. Thanks in advance for all the help.
If your not the lead dog, the view never changes.
kendog is offline   Reply With Quote
Old 12-19-2004, 04:05 PM   #2
goldwing2000
goldwing2000's Avatar
You know this is the Blazer section, right?
Anyway, sounds like a sticking door in your HVAC box or a bad vacuum diaphragm (or cable, not sure which your uses). Stick your head under the dash and see if you can see the control units for the doors (there should be three: one to control direction of flow, one to control fresh or recirculated air and one for temperature). By moving the levers back and forth, you should be able to tell which is which.
~Kane
USMC
NRA
GWRRA
AMA
Remember:
Except for Slavery, Fascism, Nazism, Totalitarianism and Theocracies,
WAR HAS NEVER SOLVED ANYTHING!
goldwing2000 is offline   Reply With Quote
Old 12-20-2004, 03:58 AM   #3
drink2mny
drink2mny's Avatar
I moved ya to a better area!
Support The Board
drink2mny is offline   Reply With Quote
