Old 12-23-2004, 05:39 PM   #1
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Question Recommend me a new clutch
Man, It's been a while. I have been trying to stay away from the board, it makes me crave the truck too much, now that it is in storage. But, I must ask this: My truck needs a new clutch (has a saginaw 4-speed). What is a good one to get? I want something a little better than stock with a little more grabbing power to it...any recommendations?
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 12-23-2004, 07:05 PM   #2
Harold Shepard
Centerforce is a very good clutch- it holds up very well.
Harold Shepard is offline   Reply With Quote
Old 12-23-2004, 11:00 PM   #3
gmc67swb
gmc67swb's Avatar
I have a Centerforce Dualfriction. So far, I like it. I used to get a little chatter with the old clutch when I would back up. Now with the new flywheel, clutch and pressure plate, it's smooth and grabs good. It's also daily driven.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 12-24-2004, 12:52 PM   #4
crazy longhorn
Fabricate till you "puke"
"Ditto" on the Centerforce ! My longhorn runs a dual friction setup ......i like the lite "feel" of a diapragm plate, but still have the clamp, with the weights on the fingers. My clutch has been abused pretty good, & hasnt given a bit on trouble.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-24-2004, 02:49 PM   #5
MandarinSixSeven
Seasonal Poster
Awesome. Thanks guys, Sounds like centerforce all the way. I will definately be looking into the dualfriction.
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
