Old 12-29-2004, 11:48 PM   #1
chevybill
chevybill's Avatar
Talking How to install rear springs?
In a couple more sessions, my front suspension rebuild will be completed.
Once I remove the rear springs to replace with my 3 inch lower springs, how can I install the new springs?- Other than a spring compressor?
Could I set my old six cylinder over the rear end to compress the suspension so I can install the shorter springs?
Any ideas appreciated.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 12-29-2004, 11:51 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You don't need to compress the rear springs. Just support the frame on jack stands and bolt the springs to the arms on the bottom. Then, jack the rearend up until the top of the springs touch the frame and bolt them to the frame.
Old 12-30-2004, 12:03 AM   #3
chevybill
chevybill's Avatar
thanks for the advice, i wish the fronts were as easy as the rears.
Old 12-31-2004, 04:58 AM   #4
Sublvr72
Sublvr72's Avatar
rear springs are easy, I can have the swap done in 1/2 hour as long as the bolts are not rusted. all you do is unbolt the spring cups (one bolt on top and one on bottom) and they slide right out...
Sublvr72 is offline   Reply With Quote
