01-07-2005, 05:46 AM | #1 |
Parking Brake Spring?
On my '71 GMC, the parking brake pedal is not coming up fully when I pull the release toggle. Is there a lost spring? It used to pop right up. Now the parking brake is sometimes at halfmast when I take off into traffic. I have to pull it up with my big toe. I looked in one vendor's illustrated catalog but didn't see any replacement springs for sale there. So what gives?
01-07-2005, 07:42 AM | #2 |
It might be the cable has stretched out and readjustment may be a solution.
1968 Chevy 4x4 307 4 speed |
01-07-2005, 10:27 AM | #3 |
There is a small spring that restores the parking brake pedal lever within the assembly. Just check out any similar truck at a pick&pull and get the spring. Mine is the same way but haven't replaced the broken spring yet--hope to get that done within the next 7 years of ownership.(:>)
01-07-2005, 11:01 AM | #4 |
I use an old brake spring on mine, re-bend the end, works great!
01-07-2005, 12:04 PM | #5 |
Do you have a 2 wd or a 4 wd?
Jim |
01-08-2005, 02:28 AM | #6 |
Jim: It's a 4wd K/1500 Jimmy (like K/5 Chevy Blazer).
BigBlue72: I can try a generic extra spring if all else fails. Mike: I'll check it out for cable stretch. Huck: I have a '72 K/5 rolling frame for a parts truck and a K/5 cab/cowl-windshield frame section that also still has a parking brake on it. So I can resource on my own property first. Thanks Brothers -- now I know where to look.
