Old 01-28-2002, 02:45 PM   #1
johnymac
Question Doetsch tech nitrogen shocks.
Has anyone bought or know anyone that has these drop shocks? If so, are you/they satisfied? I was told that these were nothing more than a Gabriel shock shortened.
I have bought and put on my truck, but put the truck away before had a chance to really drive with them.
Thanks.
[This message has been edited by johnymac (edited 01-28-2002).]
johnymac is offline   Reply With Quote
Old 01-30-2002, 07:12 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
I have those shocks on my truck. Really can't tell if they work really good. I can see that they don't support my truck very well because of the way they bottom out. They don't necessarily bottom out but they sure do come close. My truck is a little stiff too. I have a front sway bar and traction bars on the back. I say use some extensions and use some Monroe shocks on the back. I will wear mine out then use the shock boltup extensions. For a street daily driver they seem to be okay. For perfomance truck like mine they just don't cut it very well.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-01-2002, 09:28 AM   #3
69 longhorn
Post
johnymac,My ranger had a set of D-Tec slammers when i got it. I felt that they were a firm ride,but didnt run them too long(the truck was too low to have geometry right on),so I lifted it some & went w ith a monroe shock. I have been looking at the D-Tecs for the longhorn,as i need short shocks(cut coil front,& flipped rear). This may scare a few,but Im a welder.....& have shortened my front shocks! Its been 10,000 mi,& no trouble,but the shocks are worn out. Any input on how the shocks feel on your truck would be appreciated ..... 69 Longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 02-01-2002, 04:52 PM   #4
low 84
low 84's Avatar
Lightbulb
I've just installed these shocks on my truck. I lowered my truck 5/7 and needed a stiffer, shorter shock. It seems the main advantage is that they help counter the bouncing a lowered truck wants to do when going over humps. They won't eliminate it but they do help. My last lowered truck had KYB's and the front end was pretty bouncy when going over humps. I would recomend these shocks only if your truck is really low, like mine. They are stiff but it is neccessary to keep the truck from bottoming out all the time. If your truck is only slightly lowered I agree with gchemist, go with a more high performance designed shock.
my 2 cents
'84 1\2 ton swb, 350 5\7 drop
just sold '64 1\2 ton
4\4 drop with built 350 (my toy)
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-01-2002, 04:56 PM   #5
low 84
low 84's Avatar
Lightbulb
forgot to say:
these shocks are not just shortened they are calibrated with a different psi for a lowered truck
'05 1500 Crew Cab
RIP
Old 02-01-2002, 07:43 PM   #6
69 longhorn
Post
I have a 3/5 drop,with the body also dropped 1 1/2" over the rails. No parts are bolt on,cut coil front,& rear axle flipped/hangers relocated,& a couple leafs removed. It doesnt have a bad ride,or problems with bottoming......maybe the best way would be to fab some shock brackets & run a good set of Monroes. 69 longhorn
Old 02-08-2002, 09:03 AM   #7
MOTHERTRUCKERS
Post
Anybody using HAL coilovers now called QE1 with the 12 way adjustments?
www.mothertruckers.net
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
