Old 04-09-2002, 02:25 PM   #1
chevy68388
king $h!t
chevy68388's Avatar
Post has any one used axle shims
i am geting ready to put my lift on win this thought came past my mind my axle isnt going to set at the right angel any more i heard of axle shims but most people use the on lowerd car and such
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s
chevy68388 is offline   Reply With Quote
Old 04-10-2002, 07:22 AM   #2
69 longhorn
Post
I have used them ,on lowered ,or modified suspensions. Raising can do the same thing. Shims should be available at your local spring shop,& they can supply you with a spring center bolt that has a longer locator pin if need. Good luck.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-10-2002, 04:38 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Post
May not be much of an issue, depends on how high you are going. Usually you don't have a problem with a 4" lift, probably an issue with a 6" or higher.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-10-2002, 08:29 PM   #4
chevy68388
king $h!t
chevy68388's Avatar
Post
well the lift is six inch and i have a three inch body lift
