Old 04-10-2002, 08:29 PM   #1
DARK OLIVE 72CHEYENNE
DARK OLIVE 72CHEYENNE's Avatar
Post trucks uneven????
my truck is a 72 shortwheelbase and the front end sets 2 inches lower on the drivers side front,,than the other side what would cause that?? ive changed the cois put new ones on..and its still the same..and the cab mounts are good too,,,what could it be? the shocks,maybe? when i measured the hieght of each shock,they were an inch different,,can you help o this,,,thanks
DARK OLIVE 72CHEYENNE is offline   Reply With Quote
Old 04-10-2002, 08:34 PM   #2
chevy68388
king $h!t
chevy68388's Avatar
Post
has it ever been wreaked my was and it still to this day dosnt sit rightbut also my frame bent the tryed to make it straight again but they didnt do areal good job
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s
chevy68388 is offline   Reply With Quote
Old 04-13-2002, 03:39 PM   #3
Desert Rat
Desert Rat's Avatar
Post
Is it with someone sitting in the truck when you measure? maybe one exhaust manifold is heavier,tires got same pressure?My box does this on mine.HEY you could always put a 2" drop spring on the one side.Kinda cheesy but it may work.
Desert Rat is offline   Reply With Quote
Old 04-14-2002, 06:21 PM   #4
billogna
billogna's Avatar
Post
I've had one coil cut shorter than the other for four years and it doesn't bother me. I had a frame shop look at my truck and it's got a buckled frame. It could be fixed with "only" four or five hours of labor, but I'm a cheap skate. I'd rather find another sb frame, like that's gonna happen...
'69 Custom 10 SB
'66 Mustang Sprint
'77 Sportster
'69 Chev Cust/10 swb, 350/700R4, 5"/6"
'70 Chev C10 swb, 67 front, 454/700r4, 4"/5"
'73 Chev stepper, 350/3 spd
'84 Chev K20 350/4 spd
'91 GMC 1500 Suburban 4x4, 350/700R4
billogna is offline   Reply With Quote
Old 04-15-2002, 04:03 PM   #5
1-PU70
1-PU70's Avatar
Post
Check the radiator core support bussings.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 04-18-2002, 09:38 PM   #6
loenuf
Post
check and make sure your lower a arm is not bent, and check the rear end and make sure both spring packs or coils are the same hight.....
loenuf is offline   Reply With Quote
